Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Delaware Radio Discussion Forum
Delaware Radio Discussion Forum Forum for discussing Radio Information in the State of Delaware.
Old 05-24-2009, 12:31 AM
e911god's Avatar
Default Scanning I-95 through Delaware...
Planning my trip from the Northeast to Florida. After coming over the Delaware Memorial Bridge from Jersey, can anyone give me some information on what to scan until I reach Virginina. I'm mostly interested in the State Police along I-95.
Looking at the map, it appears New Castle County is the only county I would need to monitor. Which site ID's should I add...001, 102 and 103 ? Or should I add the others for better coverage. I'm using a PSR-500 with the roam feature.
And anything other the the standard New Castle SP and New Castle County PD/Fire TG's?
"Second place is the first loser."
Old 05-25-2009, 08:35 AM
de784's Avatar
Default Ncc
I would use the DSP Newcomm Dispatch along with NCC fire dispatch and tac channels also would not hurt to punch in the TMC talkgroup it is used for traffic reports hope this helps.Have a safe trip
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
Old 05-25-2009, 03:19 PM
hai_akeeba's Avatar
Site 001 should be sufficient. There are towers in the area that should provide coverage from Salem County, NJ well into Maryland (tower at the DE/MD toll plaza). As talk groups, any with the designation of N- or SW of interest would be good. Don"t forget N-DRBA ENF and N-DRBA Tac1(Delaware Memorial Bridge Police).
hai_akeeba
Old 05-25-2009, 06:35 PM
Wiki Admin
Actually I have found that site1 doesn't cover that area all that well; I'm using a 396 with a Spectra, and reception/decoding is very spotty until you get around the split where you choose to either go to Pa or toward the Memorial Bridge. That's coming North, of course. 73 Mike
Old 05-27-2009, 07:46 PM
Audiodave1's Avatar
All good information. Don't forget the DRBA Police TG 6032.
Anyhow, once you ge to the MD line you can tune into possibly the worst sounding repeaters known to man.
151.040 carries the police traffic down to MM 75 or so just north of Balto. It repeats the MSP/JFK Highway channel ( Check the dB as I for get the freq but it's 39Mhz)
Once you get to Baltimore / I695 you'll have to put in the MSP low band channels.
Dave
If bad sound were fatal Audio would be the leading cause of death!
Old 05-28-2009, 03:00 PM
Dispatcher308's Avatar
egod 911,
Here is some info or your I-95 travel thru Maryland. Maryland State Police JFK Highway (MSP) 39.240 PL 127.3 and 151.040 (simulcast but sounds horrible) cover I-95 from exit 109 to exit 64 (Baltimore Beltway). Then the Maryland Transportation Authority covers from Exit 64 thru exit 49 they are on 453.100 PL 127.3, from exit 49 to MM 46 it is MSP Golden Ring 39.440 PL 110.9, then from MM 46 to the Prince Georges County line it is MSP Waterloo 39.420 PL 110.9 from there it goes to MSP College Park on 39.360 which will take you all they way to the VA State Line.
Hope this helps.
Nathan
Every cloud has a silver lining!!! Except for the mushroom shaped ones, which have a lining of Iridium & Strontium 90.
Old 05-28-2009, 09:33 PM
e911god's Avatar
Thanks guys for the quick responses. I'm all programmed up and ready to go !
Audiodave1 and Dispatcher308...thanks for the Maryland stuff as well. Saved me from having to post in another forum.
Maryland Transportation Authority covers from Exit 64 thru exit 49...
I did not know that MTA covered any portion of I-95. I heard they were a pretty nice agency to work for and had alot of authority. Last time I was in Baltimore, I had to stop at the seaport and saw MTA PD patrolling.
Similar Threads
TK940 scanning problems mitaux8030 Kenwood Forum 4 03-13-2009 07:37 PM
Using Technology to Enhance Scanning NYRHKY94 General Scanning Forum 21 02-09-2009 03:20 PM
Can someone explain to me how priority scanning works in mixed CONV/LTR/P25 scanning? wp3539 GRE Scanners 2 09-04-2008 09:30 PM
New Forum Suggestions: Police Scanning Discussion and Fire Scanning Discussion hotdjdave System-wide Administration 17 08-21-2007 11:38 PM
Delaware State APCO-25 Digital Trunked System In Use In NJ mshumeyk New Jersey Radio Discussion Forum 0 08-18-2004 02:52 PM
