Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Delaware Radio Discussion Forum
Delaware Radio Discussion Forum Forum for discussing Radio Information in the State of Delaware.
Old 09-20-2012, 9:18 AM
robertson40's Avatar
Default cold weather fronts
would cold weather fronts affect 800 mhz and vhf signal
DEL001
Old 09-20-2012, 9:34 AM
That would depend on the front. A sharp enough temperature change could cause a temperature inversion and that could cause the signal to be refracted back down toward the surface so that a system could be heard hundreds of miles away. Although this is quite common on VHF, this will NOT happen on 800 MHz with the majority of fronts.
Old 09-20-2012, 12:39 PM
thanks and check this out VHF Propagation Map
DEL001
Old 09-20-2012, 7:44 PM
N2ICV's Avatar
Exclamation
It does happen on 800MHz! I have heard Baltimore City and Connecticut State Police TRS's from here in Southern New Jersey.
Good ducting between SNJ and VA
Mike- N2ICV, WQOG646
When my ship comes in, I will be watching trains!
My Toys
Old 09-20-2012, 8:52 PM
Wiki Admin Emeritus
I have, in fact, heard stories about having to shut down parts of the Delaware system due to ducting across the water from NJ. Yes it doesn't happen that often, but it certainly does.
Old 09-21-2012, 11:08 AM
scancapecod's Avatar
ScanNewEngland Webmaster
Send a message via Yahoo to scancapecod
I've monitored the Delaware 800 MHz TRS from Cape Cod, MA on numerous occasions. It's by and large a water path but it is certainly the result of ducting.
Scott - Scan New England Webmaster
http://www.scan-ne.net
Radio Reference MA, RI, & CT Database Admin
