Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Digital Signals Decoding
Digital Signals Decoding Discussions regarding decoding digital signals on the HF bands, including HFDL, ALE, RTTY, CW, and others.
Old 03-21-2009, 06:13 PM
Shortwavewave's Avatar
Send a message via Yahoo to Shortwavewave
Default Unid VLF 19khz Data Signal?
Ive been playing around with my sound card as a VLF Rcvr and don't hear quite alot except for the occasional odd tones, whistles(not the real "whistlers" I assume) static, and lightning crashes.
Now this morning was a bit different.
4am Central Time
SoundCard and SAQrx, and Winrad
75ft Longwire
I got this weird data signal I thought was RTTY but Sigmira, and Digipan(decoding software) just gave me a bunch of mumbo jumbo, of course thats what it could very well be.
I was hopeing someone here might know what it is, I know theres sample sites out there but good lord theres like what????...20 different types of PSK and RTTY each?
Anyways heres a sample of what I cought.
Ernie
Banshee Soundcard VLF Reciver 0-22kz
http://radiowavelistener.blogspot.com/
Old 03-21-2009, 07:58 PM
N2DLX's Avatar
Send a message via AIM to N2DLX
Sounds like RTTY of some kind. MixW wasn't returning any useful data but it seemed to freely decode garble. I tried changing the character set and baudrate and again nothing useful seemed to be there. Could be heavily coded, a non-standard baudrate, a different format (RTTY derivative), or could be too weak to get a good copy. Who knows..
Great find though!
Old 03-22-2009, 12:33 AM
Wiki Admin
I understand there's a lot of USN submarines in this area of the band - understandably heavily encrypted...73 Mike
Old 03-23-2009, 06:12 PM
Bill_White's Avatar
4am Central Time
75ft Longwire
I would like to hear some more on this setup.
There is no dark side of the moon really, matter of fact, it's all dark.
Old 03-23-2009, 06:49 PM
Well Its basiclly Just a longwire plugged into my 2nd Soundcards Mic/or Line Input, the mic gives a louder signal.
Using this Program, SAQrx (based off the original SAQ settings from Spectrum Lab)
First off just do a google, for Soundcard as VLF rcvr to get some basic info.
SAQrx
SAQ Receiver
Spectrum Lab
DL4YHF's Audio Spectrum Analyser
Winrad (as well as others)
This winrad can be used also for Higher resolution on the waterfall display but requires some fiddleing around with.
The Weaksignals Home Page
Aside from the fact a desktop computer produces a heck of a lot of noise, the "Sound Card" is a very sensitive Rcvr.
This is how I understand it depending on your sound card
44,100khz (actual RX is 0-22khz)
96,000khz (actual RX is 0-48khz)
192,000khz (actual RX is 0-96khx)
This software converts the signal to audio to which you can better understand "Hear"
Now I have been building some filters and pre-selectors to which might actully do away with the software, but the fall back is you can see the displayed freq (waterfall, and scope).
BEWARE to not plug more than 100ft of wire directly into the sound card, Due to static charges and other things.
DISCLAIMER: I will not take resposabilly for this but I have observed that on my second sound card I have plugged 250ft of wire WITHOUT diodes or resistors, for a period of 4days during a ThunderStorm and no harm was done to the Card, this of course might have to do with the ACTUAL BUILD quality of the Sound Card.
Ernie
Old 08-26-2009, 01:49 PM
As it was said above this signal is really RTTY.
Parameters if this signal:
Baud rate ~ 111 Hz,
Shift between frequencies of manipulation ~ 165 Hz, one bit as Start, 7 bits as data and two bits as Stop.
The interesting momement that the 7th bit is the controll bit. Baud rate and shift are Rare enough and interesting for VLF.
Old 09-02-2009, 08:36 PM
I gave the setup a shot last night and I was getting data also. Not sure what freq, I was just messing around with it. Besides a very bad " hum. I heard some crackles and very short whistlers. We had T-storms a few hundred miles a way so I think thats what the crackles were. I did get some very strong very loud, high pitched tones. I'm assuming those were coming from the pc. Pretty cool way to listen to VLF. Thanks for posting the details
Old 09-03-2009, 02:24 AM
http://en.wikipedia.org/wiki/Anthorn...itting_station
This is from the following webpage:
http://dl4yhf.ssl7.com/frequencies/default.txt
kHz Call ITU Act Station Locator Lang. Remarks
19.6 GBZ G Y Anthorn or Skelton ? IO84nr also GQD ?
73
Charles J. Hargrove - N2NOV
ex-NYC ARES DEC (due to ARRL Politics)
NYC-ARECS/NYC RACES/NYC Skywarn
NYDXA SWL & Scanner Net Wed. @ 9PM 441.100/145.230
http://www.n2nov.net
Old 09-03-2009, 06:23 AM
Maybe of course it is and GBK, but GBK use MSK mode FSK, GFSK, MSK, GMSK and some other modes. in here FSK-2 RTTY with non standard parameters.
Old 09-08-2009, 05:33 AM
Wiki Admin
As I mentioned in another thread, if you get into this really low stuff, you want to belong to the Longwave Club of America This club specializes in this kind of stuff - a lot of very smart folks here. Well respected organization....73 Mike
Similar Threads
Ohio MARCs Question Post 76 (Stark County) kc8lin Ohio Radio Discussion Forum 1 04-17-2005 08:55 PM
Trunking Protocols MaxTracker System Administration and Maintenance 3 01-25-2005 04:31 PM
NIA LE8 Data Mode signal bear105 Maryland Radio Discussion Forum 0 09-23-2004 05:51 PM
webpage AFS-DEC-BIN-HEX conversions Pro-95 General Scanning Forum 18 07-04-2004 04:54 PM
Data transfer in mpt-1327 network acehigh MPT-1327 and TETRA Forum 4 06-07-2004 06:17 PM
