Michigan codeplug for MD-380
fregan
Sterling Heights, Michigan
Hi all, just received my new Tytera MD-380 and struggling with the programming software (ugh!) I was wondering if anyone has written a codeplug for Michigan frequencies? I tried the Central Michigan Emergency Network, but no way to contact them for frequencies to plug into the radio.
Any help would be greatly appreciated. Thanks. 73, N8DV
N4GIX
Hot Springs, AR
I've tried to raise anyone on the MI-Statewide talk group but after a dozen calls have not received a reply. I'll keep trying later in the workday and this evening. Where in Michigan are you located? That would help a bit...
I live in Hammond, IN but the codeplug we have for Indiana includes the MI-Statewide TG because of our proximity to MI. :)
mikey60
Oakland County Michigan
send me an email at kd8atk@wowway,com and I'll send you the one I have.
KF8ZR
Maplewood, Minnesota
I have two codeplugs for michigan
I can email them to you
Chris
KF8ZR
kf8zr@yahoo.com
K1JWJ
Saginaw, MI
Michigan Code Plugs for AT-D868UN
Have subject Anytone radio on the way and need codeplug for Michigan.
Live in Oscoda and no reachable DMR repeaters in range of QTH, but .......
Reading the manuals on my Kindle, but utterly lost on the codeplug thing and how to write one.
Thanks and 73’s
Jeff
K1JWJ
K1JWJ
Saginaw, MI
How So, Please??
Start here for Michigan codeplugs WA8KIM DMR
There aren't any DMR repeaters in Berrien County so I use a Dv-mega hotspot. It really simplifies programming the codeplug if you are satisfied with the BrandMiester talk groups.
73 K8HIT
Being utterly clueless in DMR, can you explain this “simplifies programming the codeplug” to me a bit? I have no DMR repeaters near me in Oscoda either.
I greatly appreciate your time...
Jeff
K1JWJ
Hit_Factor
Saint Joseph, MI
It depends a little on the features of the radio you purchase. Generally, the hotspot is just one channel and then you could use the connect and disconnect commands to use the talkgroups that interest you.
We like to travel, so I'll take the hotspot in the RV. As we move around I don't need to change the codeplugs for the repeaters we will encounter. Just keep using the hotspot through the internet to use the talkgroups.
I'm probably not doing a good job of explaining this. Watching a couple videos about how to use hotspots and then setting up a DMR radio might help you to put together how it all connects.
K1JWJ
Saginaw, MI
Hey, I appreciate anything you share!
I have a Anytone AT-D868UN radio and a Shark OpenSpot on the way. Will use my home wifi when there and a TP-Link and iPhone hotspot when mobile/portable.
I will be using mine in our RV just as you are.
Thanks,
Jeff (K1JWJ)
