Go Back   The RadioReference.com Forums > Amateur Radio > Digital Voice for Amateur Use
Digital Voice for Amateur Use - Discuss use of digital voice technologies on the amateur radio bands. This is to include technologies such as VoIP, P25, DMR/TRBO, NXDN, D-STAR, etc.
Old 01-07-2018, 8:45 AM
jonwienke's Avatar
Default Using MMDVM to link to sites
Could the MMVDM unit be used to link 2 sites privately without using any public radio network?
Old 01-08-2018, 10:20 AM
I don't know for sure but I can't see why not. It would probably involve editing the host files on whatever software you're using and standing up your own reflector/talk group. I also don't know if you could restrict access to your group if someone got access to the IP address for your server. You would still need a radio or an AMBE unit as well.
Really interesting question.
Old 01-08-2018, 10:48 AM
jonwienke's Avatar
Here's the scenario: a company has 2 physical locations, which are not within radio range of each other. The goal is to allow radio communication between the sites, without spamming them with radio traffic from non-company users. I'm assuming that a small linear amp will be needed at each site to boost the milliwatt-level RF output from the MMVDM to something adequate to cover each site. Users will have individual HTs.
Old 01-30-2018, 12:10 PM
Forts's Avatar
Mentor
The is exactly what I'm wanting to do as well, but other than the openSPOT none of them seem to directly advertise this ability. In my case I'd like to set one up in my office at work, then another at home (or wherever I may be I suppose) and be able to RX/TX the system from wherever I am. Not sure I want to spend $500 for 2 openSPOT units though so cheaper alternatives would definitely be nice.
Old 01-30-2018, 12:59 PM
n9mxq's Avatar
I know that some hate Facebook, but your answer is here...
https://www.facebook.com/groups/pist...7133627652597/
Sent from my SM-G950U using Tapatalk
Gene
Transceivers, receivers, and SDR! Oh My!
Old 01-30-2018, 1:28 PM
Forts's Avatar
Mentor
Unfortunately you have to be a member of that group to see the answer. Any chance you could copy/paste please?
Old 01-30-2018, 2:09 PM
n9mxq's Avatar
Sorry, forgot it was member only to view.. The fusion guys are outta luck, but D-Star and DMR.. well, see for yourself
Gene
Old 01-30-2018, 2:11 PM
Forts's Avatar
Mentor
Thank you sir! I've applied for access to the group but no response yet.
Old 01-30-2018, 2:12 PM
n9mxq's Avatar
Keep in mind this is for spots running Pi-star software..but I'm sure it's the same for others, if not close.
Gene
Old 01-30-2018, 2:14 PM
n9mxq's Avatar
Oh, and don't ask for help with any of the eBay Chinese mmdvm boards.. they get testy..
Gene
Old 02-09-2018, 1:28 PM
Which variant of firmware should be used for the Chinese pi zero hat boards, is it the same as HS_HAT, got one to experiment with but don't want to brick it...
Old 02-09-2018, 1:32 PM
n9mxq's Avatar
If you run Pi-star on a raspberry PI, it has a utility to update the HS-Hat
Gene
Old 02-09-2018, 1:35 PM
Ok, where is that, update in the web interface seems to just udate pi-star not the hat?
Old 02-09-2018, 1:45 PM
n9mxq's Avatar
Http://www.youtube.com/watch?v=hMr2-PT-cfw
Gene
Old 02-09-2018, 1:55 PM
n9mxq's Avatar
Found an easier way.. MMDVM Firmware Update 1.1.0 – R. Michael Rickey
Gene
Old 02-09-2018, 6:57 PM
I suspect that they have receivers that have very poor selectivity
and out of band rejection since they are only designed to use the antenna they come with at the power level they come with.
And their transmitters are likely not up to FCC commercial specs so amplifying them may cause interference that you will be held liable for.
An adding an outdoor base antenna will likely expose the front end to interference levels it will not be able to handle.
Old 02-10-2018, 7:15 AM
n9mxq's Avatar
They're, I believe, talking about linking over the interwebs not RF.
Gene
Old 02-10-2018, 7:36 AM
MCore25's Avatar
Vertex had a linking solution for DMR using a box which conveyed the serial output from their mobile to IP. Motorola now has something similar for the SLR1000. RF Technology has a similar feature on their Eclipse 2 repeaters when configured as base stations (difference is it'll do analog or P25).
The MMDVM is really dependent on what radio it is interfaced to add to what it can do. I also believe party of the terms of use are no commercial use (we looked at using them to build low coast tactical P25 repeaters out of).
Sent from my SM-T713 using Tapatalk
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you…
Old 02-13-2018, 10:25 AM
Forts's Avatar
Mentor
I'm eagerly awaiting mine to arrive on the slow boat from China... sounds like a neat gadget to play with!
Old 02-16-2018, 6:07 AM
n9mxq's Avatar
I'm having a blast with mine. Pi-star was a breeze to set up. I was on ait with it in under 10 minutes.
Gene
