Go Back   The RadioReference.com Forums > Software > Digital Voice Decoding Software
Digital Voice Decoding Software For discussion of software applications which decode digital voice formats such as P25, NXDN, MotoTRBO, etc. Please use the HF Digital Signals forum for anything below 30MHz.
Old 05-23-2010, 3:22 PM
Question DSD 1.3 open audio device error.
Code:
dsd
Error, couldn't open /dev/audio
ioctl reset error
ioctl speed error
ioctl stereo error
ioctl setfmt error
Audio In/Out Device: /dev/audio
/dev/audio does exist on my Linux openSuSE 11.2 distro and I am running dsd as root.
What should I look for to get dsd to work properly?
There is also a /dev/audio1 that I also tried to select with dsd -i /dev/audio1 but received the same complaint about /dev/audio
BTW, anyone know of any audio files on the Net that can be used as a sample to decode for those of us with no nearby digital?
Best Regards, Keith http://home.comcast.net/~kilowattradio/ BCProgTool.TCL 4 Mac, Win98/XP/7 & Linux
BCT15X, BC245XLT, PRO92, PRO83
Vet 101st Arbrn & 3rd ID
Old 05-23-2010, 7:39 PM
kilowa22,
I have heard this can happen if the audio device you are addressing is not recognized by Linux. Someone we know got this result attempting to use their onboard audio chipset which was not.
For them, this was resolved by installing an additional audio card, such as the cheap and readily available Diamond SX71, which is cited on *Ubuntu* sites as fully functional under that OS. Probably would work under SuSE, as well.
If you are using the native ALSA wave player, you likely already know how to determine audio1, audio2, et. al, by the command, aplay -l
Just in case, here's a link: Aplay - ALSA wiki
-rb-
Old 05-23-2010, 7:59 PM
I get the same thing from time to time. open up the alamixer and close it and try dsd again. if still not working then do a restart and try again. Sometimes you just have to talk nice to her
Brian
Uniden B C D 396 xt, GRE 500, RS PRO 197, RS PRO 160, RS Pro 528, RS Pro 97 X 2 and RS PRO 2027(this unit is the best for non digital)
Old 01-25-2013, 3:31 PM
I am getting this same error on ubuntu 12.10. has anyone figured out a fix? thanks
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
