Here's a novel idea. How about starting a working group to design a hardware solution around Unitrunker and DSD? Obviously we would need experts in circuit design, DSP hardware design, software development, and board building/testing.
I would envision a black box that would interface with a computer via ethernet IP address so it can be controlled by and viewed in any browser (similar to a Barix Instreamer). Inputs to the black box would include a discriminator (or IF) from a scanner and outputs would be RS232 or USB for scanner/receiver control.
The hardware solution would read and display legacy trunking control formats such as Motorola 3600, EDACS 9600 and 4800, LTR, Passport, Multi-Net, P25 trunking, as well as DMR trunking such as Nexedge. Also, it would read specific talkgroup and unit id data on conventional P-25, conventional DMR (MOTOTRBO and NEXEDGE) and trunked P-25 and trunked DMR voice channels (NEXEDGE).
P25 and DMR voice decode would be off limits unless we can use the AMBE DVSI chips, but that still leaves no solution for IMBE. Unless somehow DVSI's DSP software can be used.
Designing a hardware solution would dramatically improve data decoding accuracy and be a much simpler solution for the average user.
Do we have the expertise and willingness to design such a beast? I would welcome a discussion on the positives and negatives about this idea.
thanks,
thanks,
