Go Back   The RadioReference.com Forums > Software > Digital Voice Decoding Software
Digital Voice Decoding Software For discussion of software applications which decode digital voice formats such as P25, NXDN, MotoTRBO, etc. Please use the HF Digital Signals forum for anything below 30MHz.
  #21 (permalink)
Old 08-19-2012, 8:56 AM
n4yek's Avatar
In DSD 1.6 does the DSD option -ff still need to be used for the increased DMR decode capability or has the filter been defaulted into in the program?
I am guessing that is what he is referring to in the OP's New feature #2, just want to make sure.
Danny Harp Jr.
HAM Radio Operator: N4YEK
  #22 (permalink)
Old 09-21-2012, 3:16 PM
n4yek's Avatar
Been a month with no reply so I want to ask this question again:
I am not a programmer, just a curious question on DMR decoding, can the 'slot idle' information be filtered out?
That way you don't have it constantly streaming down the screen but just show the data and voice information.
I know there are no "options" in the DSD software, was just wondering if it could be written inside of the DSD program with an option to do this?
Thanks in advance, again i am just curious.
Danny Harp Jr.
  #23 (permalink)
Old 09-22-2012, 12:54 AM
mtindor's Avatar
OH/WV DB Admin
Send a message via MSN to mtindor
Keep in mind that the person who released 1.6 is not the one who originally authored DSD. He may not be wanting/willing to just pick up the project. He seems to have [very graciously] added the filtering [which makes a huge difference for me] and fixed one other problem that existed in previous versions.
But I wouldn't expect too much out of him. He has never come right out and said he was picking up the project and taking requests. And DSDauthor (the original author) has been AWOL for some time I think -- or at least not vocal on the boards.
I think we need to be happy with what we have for now. Of course, it doesn't hurt to throw out your ideas for improvements. Just don't expect anything to happy -- and be happy if/when it does
Mike / AA8IA
PSR800/PRO197
If you'd like to help me map out the First Energy P25 TRS, PM me
  #24 (permalink)
Old 09-22-2012, 7:04 AM
n4yek's Avatar
I understand he is not the original author, and I am very happy with the program. I was just wondering if that was possible and wishing that it could be done.
Thanks for your reply though.
Danny Harp Jr.
  #25 (permalink)
Old 10-08-2012, 12:54 AM
RADIOGUY2002's Avatar
Send a message via AIM to RADIOGUY2002
Default audio feed
What do I need to feed the audio to the software application if I have a gre500/600
English please, its occuiped slot 1, what else is I missing in reading this. It also tells me its mbc? How do I play the audio back to hear it?
Thanks, Ryan. Seller of Icom Radios and Others Inquire with in.
Icom F5061/F6061-5, F43/33-4, F3161-1/4161DT-2, FR3000-1, VERTEX VXR-7000D(U)
Uniden=BC-396T & 996T, Hello IDAS
  #26 (permalink)
Old 10-08-2012, 8:57 AM
mtindor's Avatar
OH/WV DB Admin
1. Your audio gain into DSD is WAY too high. You'll likely never get 1 second of audio that you can understand. Shoot for 20-30 INLVL. Anything higher and you've got too much audio gain into DSD.
2. Just because you see "Voice" doesn't mean it's voice traffic. If you are using the inverted switch (-xr) when you shouldn't be, or aren't using the inverted switch (-xr) when you should be, you'll see DSD display that voice is being decoded when actuality that isn't happening.
3. Even if you are using the right inversion and even if your incoming audio is exactly how DSD wants to see it for best decoding, it can still display Voice without you hearing anything. Why? Because DSD does not decode encrypted TRBO. If the transmissions are encrypted, it'll show Voice but you won't hear anything.
Mike / AA8IA
PSR800/PRO197
  #27 (permalink)
Old 10-08-2012, 1:54 PM
Default so lost
I need a self help manual, do i need a discriminator tap? What scanners lay nice with your software.
  #28 (permalink)
Old 10-08-2012, 5:44 PM
DSD requires a discriminator tap connection to a radio receiver. IOW, it requires unfiltered/unprocessed raw audio prior to the audio deemphasis and filtering sections of the receiver. Any radio receiver with the suitable frequency coverage should suffice though, of course, the RF performance of the radio will determine the overall performance quality you will experience. I use an old Pro-2052 and it works ok with DMR/Mototurbo. I've had no luck with NXDN but that could be for many reasons. As I understand it the software will handle NXDN (with the proper command line switches); in my case, I wouldn't be surprised if the hardware is to blame as, for one thing, NXDN ideally requires a very tight IF filter with excellent group delay (I am assuming based on my past experience with digital modulation) plus a very stable local oscillator (and probably a very low noise one as well) which most consumer quality scanners don't provide - possibly not a problem in low RF density environments but a problem in urban areas. It certainly could also be operator error as I am pretty new to DSD use and not real bright on command line expertise.
Also, the original author of DSD has not been heard from on these forums for quite some time - at least under his/her original username. Other(s) have converted the original Linux program to operate in a Windows environment and added some filtering. What you generally see here on these forums is a loose group interaction trying to make the most of the DSD software "as-is" and maybe, when possible, and when the expertise is present, occasionally tweek the software a little.
-Mike
  #29 (permalink)
Old 10-08-2012, 8:40 PM
Well, I guess the question would be if I get the psr-500 can the standard ports be used to do the feed breakdown.
  #30 (permalink)
Old 10-08-2012, 9:10 PM
Chauffeur6's Avatar
DB Admin
No. As previously stated, DSD requires raw, unfiltered discriminator audio. The make/model of scanner/receiver is irrelevant, it only needs to receive the frequency you intend on monitoring, and have a discriminator tap.
  #31 (permalink)
Old 10-08-2012, 9:18 PM
scannerfreak's Avatar
Moderator
If you get the PSR 800 you can use the built in IF audio out option right out of headphone jack to feed DSD.
Forum Rules and Guidelines
  #32 (permalink)
Old 10-08-2012, 9:22 PM
No. The 500 does not have a discriminator output as standard. You would have to open it up and do the modification yourself. The PSR800, on the other hand, as I understand it, does have the capability to send true discriminator audio directly to the headphone jack though I have no experience with that model. GRE incorrectly labels this as a "IF output" rather than as a "discriminator" output as I recall. Also, confusingly, the "IF" in the label for the "PC/IF" port of both models stands for "interface" as in "PC (I)nter(F)ace" which is for the computer control of the units as well as outputting processed digital bitstreams for trunking control channel data from EDACS, Motorola, and P25 trunking control channel decoded data.
People understandably get these confused all of the time. In my mind, GRE has done a poor job of labeling and clarifying the use of these ports to the less technically inclined user.
In a nutshell:
PSR500
PC/IF port = PC interface aka computer control interface also capable of outputting processed digital data which results from the demodulation of some trunking schemes (Motorola, EDACS, and P25). This has nothing to do with either a discriminator output or a separate output for the receiver's final intermediate frequency (IF) section.
There is no stock discriminator output available on this model therefore requiring internal modification to allow that capability if the user desires.
PSR800
PC/IF port is same as above, however, the unit also has the ability to send discriminator raw audio (as far as I know - with no processing) to the headphone jack thus requiring no internal modification for that capability. This is, or at least used to be incorrectly labeled as "IF Output"; I have no direct experience with this unit and do not know if GRE has changed their nomenclature in newer software/firmware and/or user manuals. The correct label for this would have been "Discriminator Output" which would have been quite clear. A true "IF Output" would tap the output of the final IF BEFORE the discriminator section or any demodulation section.
All I know of the Uniden HP-1 is that it has some kind of data output but I am unclear what its characteristics and limitations are.
-Mike
  #33 (permalink)
Old 10-09-2012, 8:16 AM
Forts's Avatar
Mentor
Send a message via ICQ to Forts
DSD will work with conventional NXDN, but not trunked NXDN.. which is what you are most likely trying to listen to.
  #34 (permalink)
Old 10-09-2012, 4:02 PM
freqhopping's Avatar
I hadn't been follow the whole DSD thing since it was only for Linux. Just download the Windows version to try and I've got it working for the most part right away.
BCD996T tapped and fed into the only audio input on my Asus A73E
The only issue though is that I still hear the raw input over top of the voice so I can't really make out what is being said.
Spinning & Grinning
R10 - BC890XLT - BCD396XT - BCD996T- PSR-800 - Pro-106 - MilTenna LP in the attic.
  #35 (permalink)
Old 10-09-2012, 4:23 PM
Forts's Avatar
Mentor
You will need to go into your Windows sound settings and mute the Mic input.
  #36 (permalink)
Old 10-09-2012, 4:30 PM
Make sure that you uncheck the option to listen to the line or mic (whichever input you are using for the DSD input) recording device in the sound options in Windows. If you're listening to the input while DSD is running then, yes, you will hear the raw input sound as well as the decoded audio.
-Mike
  #37 (permalink)
Old 10-09-2012, 4:47 PM
Possibly. I am pretty new at DSD and correctly identifying the different variations of DMR and PMR conventional and trunked. The signal I am attempting to monitor is pretty constant so could be a control channel for either the NEXEDGE or iDAS trunking format. But then the DMR/Mototurbo signals are also and these do seem to contain audio information. NXDN, of course, is a completely different animal. All I can say is that the signals stay on the same frequencies (as far as I can tell in limited observation but one is definitely fixed on a single frequency) and I note no other apparent voice channels though these would be easy to miss in the busy UHF business band in my area.
Anyway, I'm a newb so operator error and ignorance are absolutely relevant factors!
-Mike
  #38 (permalink)
Old 10-10-2012, 8:03 PM
Default Looking for some help...
I will say upfront I am very new to this DSD monitoring. I was previously using the earlier version of this program which had the motorola reverse program already included in the download. I understand that this new version has "self detect" ability, but I am not having any luck with the TRBO system I am listening to. How would I reverse the signal? Also I am hearing noise(?) through my speakers and a lot of data is showing on the display, but the voice is like Mickey Mouse. Any suggestions? Thanks Jeff
  #39 (permalink)
Old 10-10-2012, 10:36 PM
Use the -xr switch after the command.
dsd -xr
Midwest Grant Pages for IL, IN, WI, MI, MO, IA, KY - http://www.midwestgrants.com
  #40 (permalink)
Old 10-11-2012, 7:35 PM
That is where some of my problem lies..I am not aware of how or where to make those changes to show the -xr . I just zipped open the download , opened the folder and the "dsd" was already there. I dont know how to manipulate the commands?
