| Digital Voice Decoding Software For discussion of software applications which decode digital voice formats such as P25, NXDN, MotoTRBO, etc. Please use the HF Digital Signals forum for anything below 30MHz. |
10-11-2012, 11:59 PM
Seņor Member
Open the DSD folder in Windows Explorer.
Right click and select New Text Document.
Double click the new file to edit in Notepad.
Type the following in Notepad:
Select File, Save, and Exit.
Go back to the Explorer window and rename above file to "sh.cmd"
Double click the renamed file. You now have a command window where you can type DSD followed by whatever options you like.
11-01-2012, 8:26 AM
I just found this update and I have a question or two. Do I have to delete dsd 1.4 first before I run dsd 1.6?
Do you still access dsd 1.6 from the command prompt?
I did download dsd 1.6 and ran it, but I can't seem to do anything from the command prompt. Now that I have dsd 1.6, I can't go into dsd 1.4 from the command prompt because it comes up as dsd 1.6. do I have to delete dsd 1.6 in order to work with dsd 1.4 at the command prompt?
Moonbounce
11-02-2012, 2:33 AM
New DSD Windows Build 1.6
hi i am trying to get this thing to working on trbo only, or - FF command
can some one please :-) walk me through on the foum or by PM?
to type in the right commands to get up and running?
i an a real nub when it comes to this but willing to learn and listen,
have gone though the fourms and still confused how this thing works.
thank you in advance
tyytor
The secrecy of my job prevents me from knowing what i am doing.
Pro-2096, BC-296D, Pro-2026, BC-9000XLT, Pro-2052,
BC-350a, Pro-92b, DX-400, Pro-106 ect....
11-10-2012, 3:31 PM
Dowload link down
Can someone supply an alternate download link, or even better, the source code for DSD 1.6? Minus seems to not work. Thanks.
12-17-2012, 10:15 PM
I am also looking for an alternate download site. Thanks
Tommy J.
Nevermind, found it on a russian site.
12-18-2012, 12:22 AM
don't click the ZIP graphic, click the DOWNLOAD link below it.. Worked fine for me.
Gene
If you can't post something helpful, don't post.
01-02-2013, 10:20 PM
Link does not work as above info. Click download goes "page not found"
Anybody able to provide a link or maybe email it. Thanks for your time.
01-02-2013, 11:30 PM
OH/WV DB Admin
Digital Speech Decoder (software package) - The RadioReference Wiki
Every link on that page for downloads works, to some extent. If you download from any of the Minus sites, make sure you get to where you see:
Download (xx.xx kb)
Click on the word "Download". Any other place that you click on within one of those Minus links will get you nowhere.
M
01-28-2013, 10:00 AM
Here is a link too it i downloaded forever ago. Uploaded this myself. enjoy! https://www.dropbox.com/sh/jao74dldfmhgxk7/biQf-nlcJn
own a pro 404, and a bct 8 with a discriminator tap.
02-13-2013, 8:54 PM
DSD Windows build 1.6
Tried to download it, but have failed.
Does anybody know the correct address for the download?
02-13-2013, 9:40 PM
OH/WV DB Admin
Just a couple of posts above I posted a link to the RR Wiki for DSD. On that page there are many links for download. I guarantee one of them works.
02-21-2013, 8:19 AM
Couple of questions...
Will this work on Windows 8?
Once I install the .exe file, do I need anything else?
02-21-2013, 12:30 PM
OH/WV DB Admin
You need cygwin1.dll in the same directory [or in a different directory but in your path]. CygWin is available from Cygwin
m
02-22-2013, 11:27 PM
in my link above i have uploaded the cygwin file and dsd in my drop box. I believe i have some older versions of dsd if anybody wants those also.
02-23-2013, 6:21 PM
The link does not work. I even tried signing up for Minus to get to download the file, there is no green light here. Just a red light.
02-23-2013, 7:02 PM
OH/WV DB Admin
Sometimes the minus links work, and sometimes they do not. Are you scared of that backup site for some reason?  It wouldn't be listed in the Wiki if it weren't felt to be safe. Of course there is no cygwin1.dll on the backup site. You'd have to fetch that from Cygwin.
02-24-2013, 12:28 AM
My link works fine for me? If it's not i can re upload to another site.
03-19-2013, 5:10 PM
Here is a link to Wiki where I got my download: Index of /dsd
Now if I could just find a link to text instructions for dsd 1.6  .
Moonbounce
03-19-2013, 5:23 PM
drop box link worked for me  wtg!!
both links actually worked : )
04-04-2013, 2:12 AM
change default audio in or out
Hi,
I want to try dsd 1.6 with the WebSDRsoftware as receiverr, which use default audio output too.
There is any way to change the default audio in or out in DSD?
Thank you,
Dan
