Go Back   The RadioReference.com Forums > Software > Digital Voice Decoding Software
Digital Voice Decoding Software For discussion of software applications which decode digital voice formats such as P25, NXDN, MotoTRBO, etc. Please use the HF Digital Signals forum for anything below 30MHz.
Old 09-28-2012, 1:58 PM
Default listening to mototrbo
I want to begin listening to my cities mototrbo system. It is trunked. I would like if someone can send ke in the right direction as to what cables to buy and how to install them. I know you have to open the scanner up. Btw i have a pro 197. I am somewhat handy, is there any sautuering or anything? Would really appreciate any help.
Old 09-28-2012, 2:27 PM
If you find someone that can do that for you, please post the info--A lot of us would be interested.
I learned how to do sautuering when I was young, but now I like to saunter.
Do you have your Extra class ticket?
Old 09-28-2012, 2:38 PM
no I do not have my extra, only a techie. I can Sautuer, weld, cut metal anything really. I am a Jack of all trades.
Old 09-28-2012, 4:34 PM
gewecke's Avatar
Thumbs up
Try learning how to solder, it works much better.
73,
n9zas
Old 09-28-2012, 6:18 PM
To get serious, but only for a minute, you can't monitor TRBO with your scanner. There is one non-TRBO reception method available but you'll have to search for it on this board as I'd don't remember its name.
Old 09-28-2012, 7:27 PM
MikeOxlong's Avatar
KB1UAM, you'll need to open up your scanner and install a discriminator tap. Search and you should find the details for your particular unit. Yes, you will need to solder to the circuit board within your scanner.
Once you get that installed, look for a program called DSD. There's Linux and Windows versions available.
Use a standard audio cable to hook your discriminator tap on your scanner to your computer's soundcard and then run DSD.
You'll have to tweak things but if you search the already existing threads, you'll find lots of suggestions.
Mike.
Old 10-03-2012, 6:19 PM
DSD software can decode digital voice provided it's not encrypted, but cannot deal with
the trunking part of the system i.e. will not follow a conversation. Only alternative I know
of is getting a real radio and programming the system(s). That's a fair expense for radio,
special programming cable, plus special software and need to know a lot of system details.
DSD needs a fair bit of CPU power (at least for the Windows version, not sure about
Linux); at least dual-core.
Dave
Old 10-03-2012, 6:38 PM
gewecke's Avatar
Question
Dave
quad core, windows 7 home with 5gb Ram...will that work?
73,
n9zas
Old 10-18-2012, 2:29 PM
Yes, that'll work.
For the Ubuntu version of DSD you'll get away with a much lower spec of machine....I've run it very happily on a Netbook.
Old 01-06-2013, 5:34 PM
Are you saying-put the tap on?,then download something off the computer to scanner?
Discriminator Tap PRO106-Pics Included
Old 01-06-2013, 5:50 PM
Wiki Admin Emeritus
It's more 'install a tap' not 'put it on' - and here's the wiki page for DSD
Digital Speech Decoder - the RR Wiki
Old 01-07-2013, 10:46 AM
Yeah, I saw that 1,000 times. Always takes me in circles-theres no mention of pro 106-so I hit the top of 6 downloads, or 4 and 2 whatevers..takes me here
https://github.com/szechyjs/dsd
Please note that GitHub no longer supports Internet Explorer versions 7 or 8.
We recommend upgrading to the latest Internet Explorer, Google Chrome, or Firefox.
If you are using IE 9 or later, make sure you turn off "Compatibility View".
I know my computer brain -dell, money pit..Its at least 10 years old,been crashed by the kids-rebuilt,now I got this dell p.o.machinerey.
