Go Back   The RadioReference.com Forums > Software > Digital Voice Decoding Software
Digital Voice Decoding Software For discussion of software applications which decode digital voice formats such as P25, NXDN, MotoTRBO, etc. Please use the HF Digital Signals forum for anything below 30MHz.
Closed Thread
  #481 (permalink)
Old 07-04-2014, 4:08 PM
Forts's Avatar
Mentor
Then it'll be someone else's turn to upload it
  #482 (permalink)
Old 07-04-2014, 6:18 PM
DaveNF2G's Avatar
I think Firefox might be getting too "secure" for its own good. I can't get it to go to Yahoogroups any more. It complains about the redirect. No problem with IE.
David T. Stark
NF2G WQMY980 KYR7128
"Life would be much easier if certain people realized that, on occasion, I really do know what I'm talking about." -Me
  #483 (permalink)
Old 07-04-2014, 6:35 PM
Try Pale Moon. It uses the Firefox engine, but without a lot of the more recent "improvements" that Mozilla has made.
  #484 (permalink)
Old 07-04-2014, 8:25 PM
rrbum's Avatar
Here is alternate link.
https://truck.it/p/oo0OM072su
  #485 (permalink)
Old 08-08-2014, 5:51 AM
sbarnes's Avatar
Has anyone had any issues when program is running for sometime it will decode but no voice will come thru despite the program saying it decoding voice
  #486 (permalink)
Old 08-08-2014, 8:44 AM
mtindor's Avatar
OH/WV DB Admin
Not I. Keep in mind that if you happen to be using SDR software in combination with one of the cheap USB dongles, those dongles drift all over the place. I have a Nooelec dongle, and it can't stay on frequency [or at least close enough on frequency] to be dependable for long term decoding.
Of course, I have other cheap dongles that do stay [relatively] on frequency after they warm up. But the Nooelec Nano I have drifts all over the place the whole time it is fired up.
Mike / AA8IA
PSR800/PRO197/BCD436HP/BCD536HP
  #487 (permalink)
Old 08-08-2014, 7:23 PM
fmj fmj is offline
This mirror should stay up indefinitely
http://sdrsharp.tk/
  #488 (permalink)
Old 08-20-2014, 12:47 PM
DaveNF2G's Avatar
Per the DSDPlus readme file:
-D1 -D2
Use -D# to control which DMR voice slot is decoded and synthesized.
When I attempt to use -D1 as a command line parameter, the program spits back an "invalid parameter" error.
David T. Stark
  #489 (permalink)
Old 08-20-2014, 2:03 PM
Forts's Avatar
Mentor
Use -1 or -2. That seems to work ok.
  #490 (permalink)
Old 08-20-2014, 8:47 PM
DaveNF2G's Avatar
Same problem.
Invalid command line parameter: '-1'
David T. Stark
  #491 (permalink)
Old 08-25-2014, 2:18 PM
zwc zwc is offline
Happens to me occassionally. I fix it by stopping HDSDR and then shutting down DSD+. I then restart HDSDR and DSD+. Always works for me.
If you never can hear decoded audio or only hear occassional beeps you have to check your volume settings.
If DSD+ never starts to decode at all you have to set your input and output audio devices properly.
Hope this helps!
  #492 (permalink)
Old 08-25-2014, 3:24 PM
I have the same issue with the Noolec drifting as well. I thought it was my setup only, but appears other people have it as well.
  #493 (permalink)
Old 09-08-2014, 11:08 PM
Can someone run this captured audio through dsd+. it can't seem to run it.....
Zippyshare.com - Unknown.wav
  #494 (permalink)
Old 09-09-2014, 9:24 AM
Sorry, Its from a new edacs system..
  #495 (permalink)
Old 09-10-2014, 6:52 PM
Forts's Avatar
Mentor
A new EDACS system? EDACS has seen obsolete for a while now, replaced by OpenSky (which pretty much flopped) and P25.
Sent from my SGH-I747M using Tapatalk
  #496 (permalink)
Old 09-10-2014, 9:14 PM
MikeOxlong's Avatar
Global DB Admin/Senior Mod
I think he's confused by the talk of a new Sudbury P25 system and their existing EDACS system.
Mike.
  #497 (permalink)
Old 09-13-2014, 8:56 PM
alright, so dsd won't decode?
did you try the .wav file?
  #498 (permalink)
Old 09-13-2014, 8:59 PM
Forts's Avatar
Mentor
Sounds like a mess of stuff.. definitely an EDACS control channel with what sounds like bits of ProVoice transmissions.
  #499 (permalink)
Old 09-13-2014, 9:35 PM
yes, thats what I think it is, funny thing, dsd wasn't producing anything. no errors or repeat. And my setup should have worked.
Oh well, no biggie.. I thought it was a new type of digital speech format....
Closed Thread
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
