The option to reset the recording file daily or for a certain time is great. I seem to be decoding NXDN better with this version. Id like to know if anyone else is decoding better on NXDN.
You should be decoding everything better, especially P25.
I've tested:
NXDN48 IDAS Voice - sounds great
NXDN48 Trunked Voice - sounds great
NXDN96 Conventional Voice - sounds great
- one or more of which DSD will not decode
NXDN48 trunked control channel - DSDPlus can detect this
NXDN96 trunked control channel - DSDPlus can detect this
If you know what an NXDN signal sounds like and you aren't getting any decode, force -fn or -fN and see what happens. It pays to force the mode if you know what the mode is.
P25 Phase 1 Voice - sounds great
TRBO Voice - sounds great
In all of the above, the same sample input .wav files sound better (are decoded much more thoroughly) on DSDPlus than any version of DSD that I have.
So I would really expect that for any mode it claims to decode, it is probably doing a better job at decoding it. I can say that for sure with P25 Phase 1 and TRBO, both of which I've done a lot of testing with weak signal / noisy audio source and it still decodes it extremely well.
If you're listening to a TRBO channel and there are conversations on both LCNs, you'll hear both conversations at the same time. Stereo decoding.
I haven't had the opportunity to test Provoice, but I would expect that it does a great job on Provoice as well.
