I'm starting a new thread for DSDPlus feature requests, with the hope that the author may actually read these forums.
I'll start off by adding my own request, the first one.
Of course, some of that is a really tall order since this is a voice decoder, not a trunking application. SysID / RFSS-Zone would only be applicable if for some odd reason future versions were to support limited CC monitoring of a Type II or P25 control channel.
That initial list of suggested features / improvements should piss off the author just enough to guarantee that a new version never sees the light of day
NOTE: Many of the requests above would really be helped along if people who know the particulars about where to find that data / in what types of frames the data is found would post that information. I'm sure that in the case of DMR, the DMRDecode thread likely has a lot of those details, but I wouldn't expect the author to have to go through that thread to find out those things. If you're somebody who wants particular data to be displayed and you know where it is found in the various frames, try and post that information.
- display information relevant to trunking afficionados
For trunked and conventional, whether you are sitting on a CC or a VC, display all of the really relevant information such as:
SysID / RFSS-Zone / Network ID
NAC / RAN / Color Code
Talkgroup / Radio ID
- talkgroup / radio id information should always be available by default
Right now, when it is available it is often only available by increasing verbosity. I think it should be available by default. Then again, who cares what I think.
- above information should be added to the Title Bar of DSDPlus
Perhaps this could be done with another toggle option, so that you don't have to try to catch this information as data is scrolling down the screen.
- raw input via TCP
- raw NXDN data dump
ref: http://forums.radioreference.com/2094190-post46.html
- Display Group / Data call info
For any/all systems / modes where information is available to determine this
ref: http://forums.radioreference.com/2094465-post70.html
- timestamps on output lines
- switch-induced (-tu#, default -tu1) automatic fine tuning
This suggested fine tuning would automatically cycle through the dr, dh, ds, dd, dv limits and come up with the final 'best' number for a single iteration. Perhaps even additional iterations of the whole huge multi-loop process can be done via -tu#, where # is the number of full iterations you want it to go through. I'm fairly sure the author would understand what I'm getting at here.
