Put a check mark in correct IQ, and something else You might try is clicking on the configure wheel and changing from 2048, to 1024, I had the same problem till I did that.
Make sure your speakers, or the device you want the audio to come out of, is set to default. If you change the default device you will then need to restart DSD
