What do I need to monitor DMR Connect Plus (TRBO)
bravo14
Polk County FL
I have a few DMR systems in my area what do I need to get the setup or items to monitor? I have a desktop I'm about to put windows xp SP3 on it with a week or so. I have another computer has win7 64bit. Thanks.
AA6IO
Cerritos, CA (LA County)
As Steve (above) says, get DSD+. You list the PSR-800 as one of your scanners, so you can use the IF output for the discriminator audio and run to your line-in on audio card on computer.
I have a quite a bit of NXDN here in Los Angeles. Run my WS-1080 IF out to headphone jack, plug into line-in on Windows 7 computer, turn on DSD+, and works very well. Just set up a scan list with all your DMR stations (don't think will work with trunking, so enter as conventional), put into some scan list on PSR-800, and you should be good to go. Good luck.
Steve AA6IO
bravo14
Polk County FL
Steve AA6IO
Thanks. I'll give that a try when I'm not super busy.
bravo14
Polk County FL
Here is the screen shot I have. I see NID: Site: NL: I believe NID is the system ID and Site shows site and NID I'm not sure what that stands for.
Saint
Fort Erie Ontario Canada
Went nuts
Do I need to lock out the Control Channel? The screen went nuts when it found the CC.
What do you mean it went nuts, are you seeing talkgroups coming up and radio Ids, if so then just put all the frequencies for the system in one group and scan them.
Steve
bravo14
Polk County FL
I don't see no talkgroups and freqs. When the radio is on the Control Channel keeps scrolling fast and gives catch err
bravo14
Polk County FL
I locked out the Control Channels and it is not doing nothing just sitting still lol. I have it in conventional.
Saint
Connect plus system
This is what I see on my connect plus system. I'm sitting on the control channel with a very strong signal.
Steve
bravo14
Polk County FL
The Screen Shot I posted that's all I get. The left box keeps scrolling when I have it on the Control Channel. The other boxes are not doing nothing. I'm getting 2-3 bars of signal.
bravo14
Polk County FL
I did a test on the local p25 uhf comes in clear and worked. I guess I'm too far to hear the DMR system I'm trying
Saint
Test
Try doing a search for some more digital systems, in my area I leave DSD+ on and set my scanner to do a search between 400 MHz and 430 MHz and see if DSD+ starts decoding, I also do searches between other bands with DSD+ and find other frequencies.
Steve
vince48
Central Valley, CA.
Saint
Greetings. How did you get the three other windows in DSD+ to show? I only get the usual scrolling window
vince48
Steve
bravo14
Polk County FL
Steve
I did that like 30 mints ago and did the state slers it shows provoice don't hear voice since its Encrypted. I did a search from 450-470 only finds the Control Channel for that one Power Company site. I'll try the 400-430 since we do have a P25 P l System the Military uses.
bravo14
Polk County FL
What I see for the Power Company is Con+ NID:164 Site:11 NL:10 12 26. I'm not sure what Con+ NID: NL: stand for.
The other searches from vhf to uhf and 800mhz it came up P25 Pl and Provoice
KevinC
Big Dog...celebrating 10 years of abuse!
Super Moderator
Home
Con+=Connect Plus (Motorola dedicated control channel DMR trunking system)
NID=Network ID (like a System ID in trunking)
NL=Neighbor List
