Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Digital Voice Formats
Digital Voice Formats Discussions regarding different digital radio voice formats, including AMBE, IMBE, VSELP, GSM, CELP, MELP, and others.
Old 03-03-2014, 3:31 PM
Default Difference between IMBE and APCO-25?
I have seen different threads talking about IMBE and APCO-25 digital voice formats. What is the difference between the two? Where are they used?
Old 03-03-2014, 4:19 PM
mancow's Avatar
APCO 25 is the name for a set of standards. That standard happens to use the IMBE vocoder which is another way of saying a digital voice synthesizer.
Old 03-03-2014, 4:30 PM
Thanks for the reply. So .. would it be safe to say that just because a radio makes use of the IMBE vocoder does not make it a P25 radio? But if a radio was P25 compliant it would have to use IMBE for the vocoder?
Old 03-03-2014, 4:49 PM
That's correct. The ProVoice implementation uses the IMBE vocoder, but is certainly not P25 compliant. It uses different modulation schemes, error correction, etc that is covered under the P25 standards.
For Phase I (FDMA) usage, correct. Phase II (TDMA) uses the AMBE+2 vocoder since it works better at a lower bitrate.
KC2ZHY | 1RWN NJ808 | FF / EMT | Somerset County Emergency Services Feed
* BCD996XT * BCT15X * XPR 7550 VHF Hi * HT1250 VHF Hi * XTS2500 UHF R2 *
Tags
imbe, p25
