teufler
Reviewing radios that are available on the market, I see two that are "close to initials", but have no idea how they are different or they are just the same. Can somebody expl;ain the difference??
A highly biased comparison.
What? How do you figure DMR is twice as efficient in spectrum use?I have both, and DMR is much more complicated of the two in terms of programming and twice as efficient in spectrum use.
It may be of note DMR radios with the AMBE3000 chip tend to have inital audio issues as well. You see this with most of the cheaper DMR radios. The more expensive radios tend to use a AMBE+2 chip.
It isn't - the data is just streamed differently. One thick vs two thin, in it's most simplistic format.
FDMA is to P25 Phase1
P25 Phase I is a single-user modulation. It is not FDMA (or any MA at all).
Wikipedia said:The P25 Common Air Interface (CAI) on P25 Phase 1 uses a technology known as Frequency Division Multiple Access (FDMA), where the channels are divided according to frequency. The channel bandwidths for voice and traffic channels are 12.5kHz. It is backwards compatible with analog.
Sorry P25 Phase 1 is FDMA feel free to google search and see white papers and reports from all the manufacturers of P25 Phase 1
I have known dPMR and DMR to be broken down via technology and maker type: DMR is of the likes of Mototrbo/Hytera and dPMR is of Nxdn/iDas. This does not mean these are the only ones but they are the bigger more known in the US where I live.
Here is the break down for technical reasons:
DMR - Digital Mobile Radio - Uses TDMA (Time Division) digital technology in which a 12.5 Khz channel is actually divided into a series of time slots (known as time slot 1 and 2) that are equally spaced in the 12.5 khz spacing. [NOTE: It is argued that this achieves 6.25 khz channel spacing even though using 12.5 khz because a time slot uses 6.25 of the 12.5 spacing].
dPMR - Digital Private Mobile Radio) - Uses FDMA (Freq Division) digital technology in which this can breakdown a 12.5 Khz channel spacing into two 6.25 Khz channel spacing. It does NOT use time slots like TDMA as the frequency is just sliced into equal paths within a 12.5 Khz channel.
Hope this helps and does not hinder.
