edwardscott
- Joined
- Mar 10, 2006
- Messages
- 105
anyone know anything on the progress of north durham fire depts moving to fleetnet? namely, uxbridge, brock and scugog? it should be happening anytime
ES
ES
I'm sure others would be quite interested in where you had seen/heard the news of this.
Proof please. I'm sure others are gonna ask the same question.
Interesting. But I thought Fleetnet wasn't a good choice for portable coverage but rather better for mobile coverage
Your answer was rude, so as well mine will be: Have you ever heard of a fire truck and a mobile repeater?
Firefighters are never not near a vehicle (in Scugog anyway). This solution would work well for them, last time I knew they were using HF radios.
Folks -- what is northern Durham fire using now for radios? Are they on the Durham trunked system?
Someone correct me if I'm wrong but I believe the car radios are 45 watt Astro Spectas fed into a wideband VHF whip. The towers I imagine are similar wattage (or less) but obviously have the advantage of height. With such a set up I'm not surprised at all that they're getting such good mobile coverage.Why is it that fleetnet/opp get such good coverage with their system? I know the towers are roughly 50km apart....i wonder what wattage they are..i assume 50 watts inside the cars, not sure what the towers are....i know a lot of systems you have deadspots and only say 10km range....
I've heard there are a couple of others (mixed mode I think) in the GTA. I need to get Astrosexy and try them out sometime.
