papascanner
- Joined
- Oct 1, 2008
- Messages
- 4
Has anyone installed the new firmware?
Any improvements on Fleetnet ?
Fixed the horrible audio clipping by changing P25 to manual.
Had to do this for each System.
Program System> "System Name"> Edit system Option> Adjust P25 Level> Manual [Press scroll Button IN]
To adjust the P25 settings while in scan.
Press and hold Function key> press Scroll button IN> press Scroll Button IN
When a P25 channel opens squelch adjust the level with the scroll knob to obtain lowest ERR number.
With P25 now set to 8, I get ERR 0 to 1 again. The audio clipping is gone/fixed.
So far haven't noticed the static lead ins on P25 Conventionals either. Will report back if they show up but for now I think everything is as good as the V2 firmware if you set P25 to manual.
All in all is it worth it to do the update?
I monitor Fleetnet and occasionally Go transit with the last update in March and heard major improvements IMO. How much if any, will my scanner work with this update?
Looking fowrard to feedback.
E
Ron: I loaded in V3. Works ok but it probably isnt all the necessary,I was reading on the Uniden forum that alot of people have refered back to the last version. I did not put in the new version as I found a huge improvement after I did the V2 update on the fleetnet and also Barrie's Fire and Police which was pretty bad.
I think for now I will be leaving V2 in my scanners since they are doing great decoding.
Anyone else here having trouble with V3 on any other digital systems.
Take care
