RF Adapters
JRichard
Miramichi, NB, Canada
I'm looking for an online source for N-type male to F-type female adapters. I see that they make them but I've been unable to find an online supplier.
Thanks,
Jeff
DaveH
Ottawa, Ont.
These must not be common, I have never actually seen one, and
I keep a good assortment of adapters around (collecting more as I go,
usually from ham fleamarkets...).
BNC and RCA to F were sold by RadioShack (not sure The Source or
the new RS sells them). Less than ideal, but you may consider going
N to BNC, BNC to F.
Dave
N
N_Jay
Guest
Be careful
Check your "N" connector.
The pin on the "N" is a different size depending on if it is designed for 509 ohm or 75 ohm use.
Using the wrong mating connector will cause a bad connection or can break the connector.
