Hello there.
I see you will be travelling to the Sault from T-Bay on Hwy 17.
When you get close to Wawa. You would want to put in these Trunk Freq's. Type this in and then look for Site 52, which is the Trunking Freq's for Wawa on Fleetnet. Then when you get real close to the Sault and also when you are in the Sault type in Site 020 which is more Trunking Freq's for Fleetnet.
http://www.radioreference.com/modules.php?name=RR&sid=3511
When you put in those freq's. You will be able to hear the OPP (Which are Digital), The MNR (Also Digital), MTO Maintenance (The Guys who do the Roads now in the Winter), and maybe the MTO Enforcement (The guys who check the Big Transport Trucks).
When you are in the Sault. You will NOT be able to listen to the Sault Police, because they are Encrypted and nothing will decode that.
But you can listen to the Fire Dept - 153.830 or 154.370 - Both Freq's are the same thing. So you can put either freq in, or you can put both in if you want.
You can also listen to the Sault Ambulance - 149.440 - Is the Province Wide Pager for them. Which is where you will hear them get paged out to where they have to go.
149.710 - Sault Ambulance - Tactical
149.215 - Sault Mobile
149.605 - Sault Ambulance
150.485 - Sault Ambulance - You can put all of these freq's in for the Sault Ambulance. You may only hear 2 active freq's from the above list, which are the main Ambulance Freq's, but just put them all in just in case.
For the Railroad. Just do a Search Range between: 159.000 - 162.000. When you do this you will hear any active Railroad Freq's that are in use.
Also if you want to hear Aircrafts. Just check this site out:
http://www.canairradio.com/ont.html
Then just look for the Sault and put those freq's in and you should be all set.
If there is other Freq's you would like to know. Just let me know.
Otherwise here they are and have a good trip to the Sault and enjoy it there.
Coolguy
