Go Back   The RadioReference.com Forums > Canada Radio Discussion Forums > Eastern Canada Radio Discussion Forum
Eastern Canada Radio Discussion Forum Forum for discussion of Radio Information specific to the Provinces of Ontario, Quebec, Newfoundland, New Brunswick, Nova Scotia, and Prince Edward Island
Old 01-28-2009, 12:26 PM
stircrazy's Avatar
Default Help programming the pro 97 with london ambulance
I got a new (new to me at least) Pro 97. The Bell Fleetnet - Ontario Provincial Government Zone 1 System for london ambulance is giving me trouble.. I have the Uniden 780xlt which is a dream to program, and I get it to work there fine. Can I listen to these channels on my new(er) scanner? Can someone point me into the right direction? I bought this one for the portability. I needed a handheld and this one came up cheap.. please help... thanks
Old 01-28-2009, 01:18 PM
Forts's Avatar
Send a message via ICQ to Forts
Yep the Pro-97 should work ok for you. Have a look at this link: Easier to Read Pro-97/2055 Scanner Manual and hopefully that will help you out. Basically you need to setup a bank for Motorola Type II trunking, then enter the bandplan details (spacing, offset etc etc). Essentially the same as what you did in your 780.
Pro-106 - Pro-96 - BCT15 - BC780XLT - Pro-433 - Pro-2045 - BC-350 - Pro-43
Old 01-28-2009, 01:43 PM
stircrazy's Avatar
wow Forts.. thanks for the super fast response.. I have alot of patience and this scanner is something new, so I know it will take a bit to get used to it.. thanks for the link too.. its helping.. lol
Old 01-28-2009, 05:06 PM
Forts's Avatar
No problem! I have a Pro-96 which I imagine programs fairly similar to the Pro-97. I can likely step you thru it in a little more detail if needed.
Old 01-28-2009, 05:35 PM
stircrazy's Avatar
i am actually having some difficulties.. and the manuals on line aren`t all too clear on the programming.. i have added London fire control chnls, in the same order as my 780xlt, followed all the directions, but i never get the tones any more.. on the basic channels i get the radio, but not the control channels.. weird.. any suggestion?
Old 01-28-2009, 06:40 PM
Forts's Avatar
Did you set the fleetmap? LFD uses Type I talkgroups so you will need to enter the fleetmap.
Old 01-29-2009, 10:25 AM
stircrazy's Avatar
Hey Forts, I tried to enter the fleetmaps and it tells me they are invalid.. i dunno anymore.. lol
Old 01-29-2009, 12:25 PM
Forts's Avatar
Do you happen to have a programming cable for your Pro-97? It can be much easier to do with software instead of by hand...
Have you taken a look at this thread? http://www.radioreference.com/forums...-fleetnet.html
If the Pro-97 programs the same as the Pro-96 (should be pretty close at least) then the steps I listed at the top of that thread should get you going for EMS on Fleetnet. Once you get it running you will need to lock out the digital talkgroups as they become active.
As for London Fire I can step you thru that one once I get home and have my radio in front of me as a reference.
Old 01-29-2009, 12:58 PM
stircrazy's Avatar
Thanks, I have entered all the correct info finally for the ambulance.. Its the fire dept I am now having issues with.. I have entered the system fleetmaps, 00 00 03 00 00 and so on. they are all stored, but i think i am missing something, because i still dont get the tones for any alarms. I only get the conventional channels.. any help would save me some hair. lol
Old 01-29-2009, 01:22 PM
Forts's Avatar
Hmmm ok.... Umm. Both the bank and channels are set to MOT? You have all 3 trunked channels entered? (860.2375, 860.4875 and 860.7375). If you park manually park on 860.4875 or 860.7375 you should be able to hear the control channel (it's always on one of those two frequencies). When scanning, does the radio pause on the control channel at all? Oh, and is the bank you are using in open or closed mode? If it's closed, make sure you have the proper talkgroups stored (200-01 for Dispatch etc etc). Do you hear any traffic at all, or is everything quiet while your 780 is yakking away?
That's all I can think of off the top of my head. I'll be able to help you better once I have my radio in my hands to play with.
Old 01-29-2009, 03:12 PM
stircrazy's Avatar
I got it.. it works now.. i was typing in just the one 0 instead of 00.. it finally took them correctly.. thanks for the help.. I do have to get the cable for this but I am in Canada so its a little harder to find.. Thanks again!!
Old 01-29-2009, 07:16 PM
Forts's Avatar
No problem, glad you got it working!!
Similar Threads
Pro 97 Scanner Programming Question dpoynter02 Radio Shack Scanners 7 08-24-2008 05:10 PM
Pro 97 and Pro 2051 cloning... btritch Radio Shack Scanners 6 03-15-2008 08:26 PM
Pro 97 not receiving freqs that my old Uniden Sportcat gets? gs_new Radio Shack Scanners 6 10-30-2006 07:06 AM
need help in programming pro 97 with alameda county freq. in california photojpix San Francisco Bay Area Discussion 2 07-20-2006 11:18 PM
programming pro 97 for motorola trunking wrench234 Radio Shack Scanners 2 07-01-2006 03:10 PM
