Go Back   The RadioReference.com Forums > Canada Radio Discussion Forums > Eastern Canada Radio Discussion Forum
Eastern Canada Radio Discussion Forum Forum for discussion of Radio Information specific to the Provinces of Ontario, Quebec, Newfoundland, New Brunswick, Nova Scotia, and Prince Edward Island
Closed Thread
Old 07-18-2005, 07:17 AM
MikeOxlong's Avatar
Send a message via AIM to MikeOxlong Send a message via MSN to MikeOxlong Send a message via Skype™ to MikeOxlong
Default Programming your Uniden scanner for Bell Mobility Radio's Fleetnet system
This FAQ applies to the BC-780, BC-785D, BC-250D, BC-296D, BC-796D ONLY. See further below in this thread for instructions on the BC-396.
This FAQ assumes that you've set the digital audio quality parameters properly before starting. If you have problems receiving the digital talkgroups, check your digital audio parameters.
This FAQ only details how to setup Trunk Search mode. If you with to use Trunk Scan mode, you will need to determine which talkgroup id's you wish to listen to and program them in accordingly.
Before getting started, determine which system you wish to listen to and which site.
For Zone 1:
http://www.radioreference.com/module...=TRSDB&sid=861
For Zone 2:
http://www.radioreference.com/module...TRSDB&sid=2560
For Zone 3:
http://www.radioreference.com/module...TRSDB&sid=3511
Although you can put more then one site in a bank, this FAQ will only deal with one site per bank.
Write down the frequencies for the site you closest to you and note which frequency is the control channel (red) and which is the alternate control channel (blue). This will aid in troubleshooting later.
Now, on your scanner press "MENU" to put you into Menu Mode.
Scroll down using the "HOLD" or "LIMIT" keys or press the number "2" to select SCAN OPTION.
Press "2" to enter TRUNK programming mode.
You will be asked to select the bank in which your trunk system will be entered. Use the "HOLD" or "LIMIT" buttons to scroll through the banks or if you know which bank you want, press the corresponding number on the numeric keypad. We'll assume Bank 1 and press "1" to start programming up Bank 1.
The first thing we'll do is enter the information that allows the scanner to follow the system:
Press "1" or just hit "E" to enter TRUNK TYPE. Hit "1" or "E" again to turn trunking on.
Scroll down (LIMIT) or press "5" to select TYPE2 VHF trunking.
The scanner now needs to setup the VHF trunking system parameters. Hit "E" to enter the BASE CONFIG 1.
Press "141.015E" to enter the BASE FREQUENCY 1.
Press "15E" to enter the SPACE FREQUENCY1.
Press "380E" to enter the OFFSET CHANNEL1 (or just press "E" to leave it at the default which is already 380).
Press "E" to setup Base Config 2.
Press "151.730E" to enter BASE FREQUENCY 2.
Press "15E" to enter the SPACE FREQUENCY 2.
Press "579E" to enter the OFFSET CHANNEL2.
Press "E" to setup Base Config 3.
Press "154.320E" to enter BASE FREQUENCY 3.
Press "15E" to enter the SPACE FREQUENCY3.
Press "632E" to enter the OFFSET CHANNEL3.
Currently most sites use only the first range of frequencies. However, the Toronto site in Zone 1 is using one frequency in Range 2. It's expected that as the system grows, frequencies in the 2nd and 3rd range will be used. Since the programming of the 2nd and 3rd range are trivial, you might as well put them in now.
Press "MENU" 3 times until you see the TRUNK TYPE menu again.
You now need to enter the frequencies for the site (you did write them down didn't you?). This will tell the scanner that these frequencies are in use for this trunk site.
Press "2" to select TRUNK CHANNEL.
Press "E" if you are sitting on the first channel you wish to store a frequency in or scroll to it (HOLD/LIMIT) or enter it directly by entering the channel number directly on the keypad and pressing "E".
We'll use channel 1 so press "1E"
You should now see 1:FREQUENCY as the first menu item.
Press "E" and enter the frequency using the keypad and end with "E". If you were programming 142.5000 into channel 1 you would press "142.5000E".
We'll leave the alpha tag empty (you can do that later) so just press "E" to bypass it.
The scanner will ask for another channel to store your next frequency in.
Press "2E" to select channel 2.
Press "E" and enter the next frequency from your list.
Press "E" to skip entering the alpha tag.
You will need to do this frequency entry routine for each frequency listed for the site.
Once you have repeated this enough times to store each frequency for the site, press "MENU" to exit back to the main trunk programming menu.
If you wish to setup a delay, press "4" to select 4ELAY and scroll through the choices. Press "E" when you've reached the one you want.
Press "9" to select 9:I-CALL and press "E" to turn it on. This will allow you to hear I-Calls although they are very rare on the Fleetnet system.
Press "0" to select 0:STATUS BIT and "E" to turn it on. This will make sure you aren't confused by the extra digits shown when status bits are broadcast with talkgroup calls.
Hit "SCAN"
You should be able to see your scanner pause on the control channel (the one in red from the database). If it doesn't then you need to check a few things which we'll deal with in a minute.
If your scanner says ID SCAN in the top left when it pauses on the control channel then you need to switch it to ID search. This is necessary since we didn't enter any talkgroups. Press and hold "TRUNK" until your scanner says READY TO ID SEARCH.
Now when it pauses, it should say ID SEARCH in the top left.
If there's any activity, the scanner should stop and show you the talkgroup id and you should be able to hear what's going on.
If your scanner doesn't pause on the control channel, then press "HOLD". Press the channel number of the channel containing the red frequency and then press "HOLD" again. This should take you to the channel containing the red frequency. Make sure there's an M just to the left of the channel number. Also turn the squelch down and make sure you can hear continuous control channel noise. If you can't hear control channel noise then check the alternate control channel (blue) for control channel noise.
If you cannot hear control channel noise then you'll probably need to explore other options such as a closer site or something to improve your reception.
If you need further help, ask here or on Scanont.
Please do not email or PM me. You will get a quicker answer using one of the above mentioned sources.
Mike.
Last edited by MikeOxlong; 11-08-2006 at 11:35 AM.. Reason: Corrections to links, Added Zone 3 link, added 2nd and 3rd range programming instructions.
Old 07-18-2006, 11:01 AM
MikeOxlong's Avatar
This FAQ applies to the BCD396T. I believe the BC246T is similar in programming however I do not have one to try.
This FAQ assumes that your digital audio settings are ok. The defaults used when setting up the system should work fine however you should probably touch them up afterwards as I find the default setting isn't the best.
For Zone 1:
For Zone 2:
For Zone 3:
Write down the red and blue frequencies for the site you closest to you. These are the control channels (primary and alternate) that the scanner will need to track the system.
Now, on your scanner press the MENU button located on the left side of the scanner to put you into -- MENU -- mode.
Your scanner should now be sitting on the Program System menu option. Press "E" to enter the System Programming menu.
If you already have systems entered in you will use the scroll knob (located on the top of the scanner) to select the New System menu entry. One turn counter clockwise should do it. Press "E".
You will now be at the Select Sys Type menu. Here you will rotate the scroll knob and select MOT and press "E".
Scroll to the VHF band entry and press "E".
Your scanner will ask you to confirm the entry by pressing "E". Your scanner should show Processing Wait, Please while it creates the system.
The scanner will give your system a name of System XX with an M on the far right of the display which denotes Motorola trunking. If you wish to change the System Name, use the Edit Name option. I'll let you RTFM to figure out how.
Scroll to the Edit Sys Option menu item and press "E".
Scroll to the Edit Band Plan menu item and press "E".
Your scanner should be sitting on Band Plan 1. The following steps will enter the 3 frequency ranges used by Fleetnet. This will allow your scanner to convert the channel numbers sent over the control channel to actual frequencies.
Currently only 1 site is using a transmit channel outside of Band Plan 1. However, since programming in all 3 band plans only takes a few minutes, you might as well take the time now and you'll be ready if they implement channels in Band Plans 2 and 3 later on at the site you have chosen.
Press "E" to start entering in the base, spacing and offset for Band Plan 1.
Press "141.015E" to enter the base frequency for Band Plan 1.
Scroll to the 15.0 kHz entry and press "E" to enter the channel spacing for Band Plan 1.
Press "E" to select the default Offset of 380 for Band Plan 1.
Your scanner will now be sitting on Band Plan 2. Press "E" to start.
Press "151.730E" to enter the base frequency for Band Plan 2.
Scroll to the 15.0 kHz entry and press "E" to enter the channel spacing for Band Plan 2.
Press "579E" to enter the Offset of 579 for Band Plan 2.
Your scanner will now be sitting on Band Plan 3. Press "E" to start.
Press "154.320E" to enter the base frequency for Band Plan 3.
Scroll to the 15.0 kHz entry and press "E" to enter the channel spacing for Band Plan 3.
Press "632E" to enter the Offset of 632 for Band Plan 3.
This concludes the Band Plan programming. Press Menu to go back to the System Options menu.
Scroll to the Set I-Call menu item and press "E".
Scroll to the On menu item and press "E". I-Calls are private calls between two radios on the system. I-Calls on Fleetnet are very rare so don't be surprised if you don't hear any.
Hit the Menu button to escape back to the main System Menu.
Now we need to tell the scanner what the control channels are for the site you want to listen to.
Scroll to Set Frequencies and press "E".
Press "E" again to enter a New Frequency.
Punch in the red frequency and press "E". The scanner should say Processing Wait, Please. This tells the scanner what the primary control channel for the site is.
Press Menu to escape back to the Sel Frequency menu.
Scroll to New Frequency and press "E".
Punch in the blue frequency and press "E". The scanner should say Processing Wait, Please. This tells the scanner what the secondary control channel for the site is.
Only one control channel at a time is active on a site. If the primary fails, the site will switch over to the secondary.
Press Menu twice to escape back to the main System Menu.
Now we'll set the system modulation.
Scroll to Set Modulation and press "E". Scroll to NFM and press "E".
At this point you should be able to press "Scan" and the scanner will start scanning. You should see the scanner briefly stop on the System and display ID Search. One of the control channel frequencies should show on the 3rd line. If there's any activity then the scanner should stop and display the talkgroup id (in decimal) on the 2nd line.
If you are having problems, you can manually go to the control channel frequency and check the signal strength.
Press "Hold" to stop your scanner from scanning. Hold down the Func button on the side of the scanner and press "7" (rcl). Use the scroll knob to select the system you just entered. Press "E" to select it, "E" again to select the system frequency and "E" again to select the channel. At this point you should be sitting on the red control channel frequency.
You should be able to hear control channel noise. The display will show Hold on line 1, SID:782Dh-0002** on line 2 and the red frequency on Line 3 alternating with any active talkgroup id's
**Note: replace 782D with the System ID of the appropriate system. 782D for Zone 1, 822F for Zone 2 and 8230 for Zone 3. Replace 0002 with the Site number of the site you are listening to. For example, somebody listening to Site 3 of Zone 2 would see SID:822Fh-0003.
If you are unable to hear any control channel noise, rotate the scroll knob to select the other control channel frequency (blue). If you cannot hear anything, then you might be out of range of that site.
Mike.
Closed Thread
Similar Threads
San Antonio EDACS system and the press blantonl Texas Radio Discussion Forum 8 05-03-2009 12:53 PM
Official Uniden BC246T Scanner Thread blantonl Uniden Scanners 1140 09-28-2005 08:01 PM
Need help programming San Fran Public Safety System cbrookhart San Francisco Bay Area Discussion 20 10-04-2004 09:52 PM
Alternatives to Uniden BC-796D? sajohnson Maryland Radio Discussion Forum 19 05-17-2004 03:06 PM
