165.2600 Pl167.9
cjrjr507
Libby, Montana
Hi
I found this while scanning (165.2600 Mhz PL 167.9) and the guy said Hungry Horse Fire (Direct). I assume it's Forest Service. The frequency might be 165.2625 if it's 12.5 khz step, found it at 5 khz step. Scanning it now to find out. That frequency is listed as DEA so checking to confirm it. Heard it before and they finally said who they were. I live in libby, mt and the signal is fairly good.
Scanner: BCT15
Antenna: Firestik base antenna
Software: FreeSCAN
davidbond21
New Braunfels, TX
All the DEA frequencies in my parts are UHF and with a tone of 156.7, whereas the FBI here I know use the PL you have listed. I think those tones are pretty common to each agency across the country, though they're not set in stone.
ecps92
Taxachusetts
Out here near the Water [New England] it's used by the USCG.
Out your way, it's likely US Forest Service, could it have been an image of another frequency?
How close are you to "Washburn" or "Tin Can" these are two USFS Rptrs using 167.9 Hz in Montana
on 164.8250 Mhz
Yes 167.9 Hz is typically an FBI tone, but also used by other agencies such as
BLM, CAP, CBP, NFS, USCG Aux, USFS, VA Hosp, USNF etc
Hi
Scanner: BCT15
Software: FreeSCAN
cjrjr507
Libby, Montana
165.2600
on 164.8250 Mhz
Hi ecps92
I live in the kootenai national forest and those are in the gallatin national forest, a long ways off, heh heh. About a good 350 to 400 miles away. And yes, it could be an image freq. Still checking it out.
stmills
Twin Cites Area MN
I believe Hungry Horse Fire district is in or near the Flathead National Forest which according to the RR database uses 165.2625 as and input to 164.375 repeater.
Steve
ecps92
Taxachusetts
But that lists a PL of 123.0 Hz, he was hearing 167.9 Hz
Are there Multiple Repeaters with Different Tones ? or maybe a Simplex Tone?
Steve
Gilligan
Hagerstown, MD
Yes, many repeaters w/ input on 165.2625 but all separate tones. All output on 164.375 w/ 123.0 PL. This way, the rangers can access specific repeaters on different mountains.
