ks4ui
Does anyone have information on what kind of radios the Postal Inspectors use or what channels they are on?
I see the reports on RR but wonder how do you know that these are Postal investigators if they are encrypted?
PI freqs used to be assigned locally from a pool that was used nation wide. The same freqs would pop up in different areas. They used to have many channels (may still have). Even though there has been a total reorg, some of the old frequencies are still being used. In my case some inputs became outputs. We compare notes here in this forum. As it turns out, other people in different areas are hearing the same freqs in use. Also, the NAC code so far has been the same (482). When someone confirms the identity (in the clear) and matches up the NAC, you can be pretty sure it is them when you get that NAC in a search. I know of no one else using it. Of course you have to be open minded to the possibility of different NACs used in different areas, but so far I have only seen one and heard of one. I expect the same type of radio system habbits and design, and so far I'm seeing it with the exception of wider area repeater design than before. These guys down here love to have long winded QSOs, and they do...especially on a Sunday mornings. Same MO as before.
There are two freqs in my area that fit the profile. I expect they have more and I'm searching with logging as much as I can. It is just a matter of time until I get some direct freqs.
407.7250 R
407.7750 R
I have heard reports of:
409.9375
The action used to be good, and when in the clear they would say way too much over the radio down here, but it was fun to listen to. Now all I hear is garble. In fact they are garbling right now!
Phil
407.7250 R
407.7750 R
In Michigan (Detroit area) I have logged both of these freqs active using a NAC of 482. Encrypted 100% of the time. Inputs are 9Mhz above this as already mentioned.
Nice catch, are you sure they are postal inspectors? Not to doubt you but I was told by someone I know who works for USPS that they make extensive use of cell phones instead of radios.
Down here in San Antonio, Texas ... Our US Post Office freqs are analog conventional UHF FM.
415.0500 = Postal Inspector, 414.7250 = Postal Ops, 415.5750 = Postal Ops ( all 3 are active ).
Yes they do use the phones extensively, however they must check in with NLECC Control from time to time over the air as to their current status/location.
