a correction on a previous statement i made:
first off i have seen 1001 too now that you mention it but i am fairly sure only in conjunction with Blue Ridge Parkway/Nat Forest/Park Rangers in NC mountains or something like that.
not quite right, notes and recent observation shows that the RID was 1001, not the TGID as i stated. most recently it was noted on simultaneous Tx's on 172.750 $120 and 172.725 $110 (may have the NACs backwards) where the TGID was 1 and the RID was 1001, so sorry bout that folks, relying on my memory is the first step on the yellow brick road to failure.
next:
I have found that in federal stuff, there are always exceptions!
I looked back through my WS-1088 and did find one FBI frequency that logged an odd talk group. 170.6250 MHz, N167 in the Houston, TX area showed a P-25 talk group of 4095. I caught that today sometime after I posted that I never caught any FBI talk groups other than 1. Other FBI frequencies in the area showed talk group 001.
- Chris
I appreciate you making the first statement, shows you are not just wise but humble as well
now that the buttering up is done, a quick question: regarding a "P-25 talk group of 4095", some time back i either read or participated in a thread on here, where that came up. it was of interest to me because occasionally i had noted FPS's 410.800 $210 (jeez i can't think today, apologies if the NAC is off) in the CLT NC area, I would see TGID 4095 in conjunction with end of shift checkin/out's, in which often one or both sides will be in the clear. typical scenario would be an on foot mobile declaring that they (by callsign) were starting or ending patrol at xxxxx location at xxxx hrs, followed by what sounds like their equivalent of a dispatcher/admin base station confirming whatever was said.
ok that said, the thread had someone on it who stated something that convinced me they were a radio tech or had legitimate familiarity with systems of whatever (motorola?) type was being discussed, and individual stated with such and such radio equipment, the default from the factory TGID is 4095.
i was wondering what your thoughts on that are, as i have zero familiarity with what was said it and its likelihood of being correct. as a layman's layman, it sounded plausible. Thanks
