| Federal Monitoring Forum The place to discuss monitoring federal government communications and related topics |
02-03-2007, 12:27 PM
OH/WV DB Admin
Heard from E Ohio - SysID: CA17
System ID: CA17
System Type: Motorola Type II VHF/UHF
Connect Tone: 116.3 hz
Signal: Normal
Base: 405.6625
Offset: 380
Step: 12.5 kHz
Ch ID Frequency
dec/hex (in MHz)
587 / 24B 408.250
759 / 2F7 410.400
TGIDs heard: 64
Unable to determine identity at this time. Not much traffic on this system.
02-03-2007, 04:27 PM
Sure looks like a Bureau of Prisons trunked system. Notice the resemblance.
02-03-2007, 06:07 PM
OH/WV DB Admin
Sure does look similar. Well, looks like I might have two prisons right on the fringe to listen to. This one and 4B1D in another post.
This is is entirely too quiet though. Not much fun to listen to.
02-06-2007, 09:39 AM
OH/WV DB Admin
Updated. Band plan that I had doesn't seem to work - when I try to enter the band plan into my 396, it says the base frequency of 405.6625 is out of band (offset 380 / step 12.5).
Saw an error in the channel IDs I monitored. Recalculated and hopefully this is correct info.
System ID: CA17
Signal: Normal
Base: 406 (thought it was 405.6625)
Offset: 407 (thought it was 380)
Step: 12.5 kHz
Ch ID Frequency
dec/hex (in MHz)
587 / 24B 408.250
632 / 278 408.8125
759 / 2F7 410.400
TGIDs heard: 64
02-06-2007, 03:47 PM
Try this:
Base: 406.8125
Spacing: 12.5
Offset: 380
See what happens.
02-06-2007, 04:21 PM
OH/WV DB Admin
Originally Posted by Gilligan
Try this:
Base: 406.8125
Spacing: 12.5
Offset: 380
See what happens.
Thank you. But that is not the proper one - That is for the prison system you told me about before, and it is different for this one. Wayne_H gave me the equation to use to figure out what to do in the event that the base freq goes below 406. Here is what he had to say: http://www.radioreference.com/forums...ad.php?t=61419
So I believe the information above is correct at this time.
02-06-2007, 06:08 PM
I would be surprised that it would have a base lower than 406. I don't know what the abilities of most UHF trunking transceivers are but I always thought they would be limited to 406-420 in that range. Oh well -- let us know what else you find out.
02-06-2007, 06:14 PM
OH/WV DB Admin
In the scanner the base is 406 with an offset of 407 (instead of the default 380). Computed base is below 406 - However, Wayne had posted an equation to use to set the proper base in the scanner for those times when a computed base is less than 405. So the scanner base is 406 and the offset is changed... rather than using the 405.xxxx base and 380 offset.
I don't have much hope of reporting anything further for this system though - since there is never any traffic on it. All day today there was one hit on one talk group and I wasn't around to catch it.
- mike
03-03-2007, 10:17 AM
OH/WV DB Admin
Updated: 3-3-07
System ID: CA17
System Type: Motorola Type II VHF/UHF (Digital)
Signal: Normal
Base: 406
Offset: 407
Step: 12.5 kHz
Ch ID Frequency
dec/hex (in MHz)
472 / 1D8 406.8125
488 / 1E8 407.0125
587 / 24B 408.250
632 / 278 408.8125
759 / 2F7 410.400
Talk Groups:
32
48
64
80
96
112
Still not able to verify identity, but probably also up in Columbiana/Mahoning/Trumbull Co Ohio area.
03-03-2007, 10:58 AM
OH/WV DB Admin
Notice my update above - The system is digital. I can't tell if its analog/digital mix or if they are running strictly digital. There definitely is P25 data on it, but its not a strict P25 System. It is Motorola.
Also, there definitely is some encryption on this system. There is a lot more activity on this system now than there was a month ago too.
