Fed freq spectrum?
ryangassxx
Banned
Inside of your head
If I wanted to set my scanner to search between two freqs that encompass the Fed band, what would they be? I know it's like 160Mhz or something like that..
rescue161
KE4FHH
Hubert, NC
The ones that we used were always from 136-144 & 148-151. I know that some agencies have a small segment up in the 160/170 range, but we never used those.
WayneH
Forums Veteran
Super Moderator
Your master site
173.2000 - 173.4000 can and will be assigned for Film and Water departments. Just a heads up. Often any telemetry heard in this range is a local gov water dept.
ETA: Corrected the range
brandon
SoCal
The real good stuff is between 167-168 MHz :)
Also don't forget the UHF fed band. I mostly search 417-420 MHz but you could extend it from 413 or so.
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
136-144 and 148-151 would be military land mobile (FM) or aircraft ops (AM).
Federal agencies primarily operate in the 162-174 VHF range. As already mentioned, fed agencies (i.e. DEA, USPS law enforcement, etc.) also use a lot of UHF.
Mick
Western U.S.
My logs in SoCal for 173-174 MHz
173.0375 “Command” “Santiago Comm” w/170.4125/170.6875/417.30
173.0500 167.9/DES FBI
173.0750 LoJack
173.1250 167.9 FBI L.A.
173.1500 P25 encoded FBI
173.1750 P25 encoded FBI
173.2500 146.2 L.A. Water & Power
173.3000 173.8 San Gabriel Co. Water District
173.3000 179.9 Lake Arrowhead Comm. Services District
173.3750 85.4 Disneyland Camermen
173.4500 P25 encoded
173.4750 P25 encoded
173.6375 167.9 FBI
173.6750 Air attack October 2007
173.7125 167.9/DES FBI
173.7375 167.9 FBI L.A./Santa Ana
173.7750 Fire, Santiago Air Ops, Or. Co.
173.8125 167.9/P25 FBI L.A.
173.9125 USFS Region 5 Tac 4
173.9750 P25 encoded
173.9875 USFS Region 5 Tac 6
wayne_h said:
173.0000 - 173.4000 can and will be assigned for Film and Water departments. Just a heads up. Often any telemetry heard in this range is a local gov water dept.
rescue161
KE4FHH
Hubert, NC
I thought military was federal. Sorry for the confusion.
ff-medic
Banned
The Appalachians - Next to the tent and campfire.
I have not made comparisons and done research in quite awhile. But " Back When" when I was seriously a die-hard " Commo Junkie "....This is what "I" had noticed.
Late 80's - Early 90's.....Most Federal Agency mobiles were VHF , and portables were UHF. I only knew of few instances in crossbanding.
Agencys in which had guards / police , that used commo, and had no vehicles or exterior patrol and worked - "In house" used UHF freqs ( Ex = Public Debt - Small VA centers - US Military Ammo and Maintenance Depots ).
Agencys that had a large area to police / patrol had both UHF and VHF radios. All the maintanence / mechanical gurus inside the perimeter ...again used UHF radios ; on both simplex and duplex. Mostly simplex...and it was not encrypted.
VHF, as I noticed sometime ago, was more common with base, fixed and mobile repeaters.
I'll have to recheck..I don't have it committed to memory now, But I believe all the federal Inter-Agency freqs are VHF ( I'll look at Wiki later ).
Like I said...back when = 80's and early 90's ; there was a patttern to Federal Freqs. One thing I belive is certain. :) US Marshalls are always on 163.200 ;)
FF-Medic - - - - -
WayneH
Forums Veteran
Super Moderator
Your master site
173.0750 LoJack
ETA: my range was off. It starts at 173.2000, so that jives with your list.
