Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Florida Radio Discussion Forum
Florida Radio Discussion Forum - Forum for discussing Radio Information in the State of Florida.
Old 01-07-2009, 12:29 PM
Default Sporadic Receptions
I am using 2 BCT8 scanners and have been monitoring the city of Lakeland with no problems. For the last month or so, I am experiencing occassional periods of no reception (The same on both scanner units w/absolutely no setting changes to scenners). It appears to be scanning normally. Some days it works, others it don't. Does anyone know what might be happening?
TX
Old 01-07-2009, 1:29 PM
Bolt21's Avatar
I discovered another control channel for the Lakeland system a couple of weeks ago. If you don't have it, it could be causing the problems you've been having. Check the database and make sure you have all the freqs for the system, including 856.4125, which is the newest control channel.
Lowly Technician-Class Operator
"If they pull guns at us, make no mistake about it, we will shoot them. A lot." - Polk County Sheriff Grady Judd
Old 01-14-2009, 9:11 PM
Default Problem with Collier Country (CC) Trunk System
Greetings: I am in East Naples, Collier County. Within the last week, Collier's trunk system has been changing its control channel up to 6 times in 10 minutes; I no longer listen. My guess to prevent monitoring. I live 1+ miles from a simulcasting tower. I have been listening to trunk systems in N.Y. for 15 years, and have never experienced this issue. Does anyone have this problem? If so, what is the reason? Thank you in advance, TCBayly
Old 01-15-2009, 9:55 AM
Bolt21's Avatar
Didn't you post about this in a Collier County thread? Your scanner doesn't follow the control channel when it changes?
Old 01-17-2009, 4:37 AM
Default Control Channel (C.C.)
Mr. Bolt12: Yes I wrote my question on this panel; nevertheless I am looking for a solution. To describe the problem: Collier Sheriff dispatchers are IDs 02-021, 02-022, and 02-023 to cover certain Zones. The county abuts Broward, and Miami/Dade counties but the bprder is 50 miles away. Let's say the tone for C.C. appears on 02-023; so I block it out. 2 minutes later, 02-021 will tone and become the control channel, and so on 5 more times this happens within a 10 minute period. The radio is set to trunk, and after going to lock out 09-85 (Marco Island P.D.) I turn off the scanner; it becomes too annoying. Any ideas? Thank you
Old 01-17-2009, 4:30 PM
Bolt21's Avatar
Last I checked, control channels occupy frequencies, not talkgroups, as you are listing. Unlike some Motorola systems, EDACS systems change control channel (frequency) quite often. If your EDACS system is set up properly in your scanner I don't know why your scanner wouldn't follow the control channel changes. You shouldn't even be hearing a control channel if your system is set up properly. An EDACS control channel (freq) will sound like a motorboat when scanning in conventional mode.
And BTW, I guess I was just hoping to hear a reply from K9Decoy reference the original thread topic before the thread was hijacked from the Lakeland topic.
Old 01-18-2009, 4:36 PM
Default Sorry
Bolt12: I am sorry for interrupting your thread. BTW, my emphasis is on an issue I have never experienced with the EDACS systems used by my Summer home P.D.s (Upstate N.Y.).
Old 01-18-2009, 5:07 PM
In addition: I believe your use of the word "hijacked" is inappropriate. BTW, you quote President Reagan; I worked for Mr. Reagan for 3 years, out of an office in the West Wing. My first scanner was given to me 35 years ago; I am not a novice to whom to be condescended.
Old 01-18-2009, 7:11 PM
Bolt21's Avatar
ctbailey,
Which still leaves me wondering why you commented on a Lakeland Motorola system thread before the original poster responded to the first reply given and before the original issue was resolved.
Sorry to offend you. In internet lingo, what happened to this thread is called "hijacking." Again, not meant to offend you.
And I'm the one who's being condescending? I even tried to help you out. Guess I need to take my Reagan quote down.
Old 01-18-2009, 7:12 PM
Bolt21's Avatar
ANYWAYS, K9Decoy, did this issue ever get resolved?
Old 01-19-2009, 2:15 AM
Bolt21: The problem has resolved as quickly as it appeared; The Sun (Spots; Flares) may have been the culprit. Whatever the reason, thank you for your help. Sincerely, TCB
Old 01-19-2009, 2:36 AM
mancow's Avatar
Well, considering there haven't been any in ages.......?
Old 01-19-2009, 9:50 AM
Bolt21's Avatar
I'm glad it worked out.
