Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Florida Radio Discussion Forum
Florida Radio Discussion Forum Forum for discussing Radio Information in the State of Florida.
Old 09-19-2009, 12:56 PM
Unhappy Osceola County
Sure world appreciate a feed from Osceola County Fire Rescue, my scanner won't pick it up and my son is on the job there.
Old 09-19-2009, 02:37 PM
FLRAILMAN's Avatar
Default Osceola County Fire Rescue
Are you trying to receive their 800 MHz trunked talkgroups or their VHF high band simulcast channel? (154.37 MHz) What kind of receiving equipment are you working with?
FLRAILMAN
Old 09-19-2009, 09:16 PM
james32746's Avatar
Send a message via AIM to james32746
I see this two ways if hick69 is using a analog trunking or P25 trunking scanner.
If 800 MHz
Probably because hick69 lives in Oviedo (SE Seminole County), he would be out of range of the Osceola TRS signal range unless he had a outdoor antenna setup with a pre-amp and 800 MHz yagi about 30 feet in the air pointed towards one of the Osceola 800 MHz towers.
If VHF simulcast of dispatch
Probably more likely to receive it than the 800 MHz on a portable, but probably still out of range. He would need at least an outdoor scanner antenna about 20-25 feet in the air to receive that signal reliably as well.
James Westerfield (MySpace) (Facebook)
Lake Mary, FL
Equipment Owned:
GRE PSR-500
Radio Shack PRO-97
Uniden BC-796D
Uniden BCD-396T
Old 09-19-2009, 09:35 PM
FLRAILMAN's Avatar
Default Ocfr
He is probably better off trying to monitor the VHF simulcast frequency of 154.37 MHz I live on the top floor of a 4 story apartment building in Orange City Volusia county & I can pick it up only at night & he is halfway between my QTH & Kissimmee, if he has roof access, all he would need is any halfway decent VHF yagi & some decent coax like LMR400 or Belden 9913 & he is guaranteed to recieve OCFR easily. I used to reside in Poinciana so I still like monitoring them, unfortunately since they dispatch & receive only in the carrier squelch mode I also pick up Sumpter County & Mt. Dora in Lake County.
FLRAILMAN
Old 10-01-2009, 09:39 PM
Not Posting
I will get a feed going soon on here. I got a couple of yagi`s about 64 ft up. I can pretty much pick up any TRS in central Fl.
Old 10-02-2009, 02:23 PM
FLRAILMAN's Avatar
Default OCFR feed
Now that could work, thanks in advance.
FLRAILMAN
Old 10-03-2009, 02:08 PM
Bolt21's Avatar
Also, while we're at it, could someone update the SO Dispatch and TTY talkgroups? When I pass through Osceola, I hear Dispatch traffic on TTY TGs and vice versa. I just don't spend enough time there to investigate it myself.
KI4Q** (Lowly Technician Class Operator)
An assortment of radios that a quattuornonagintillion other people have too.
I HOPE I end up with more than CHANGE in my pockets.
Old 10-05-2009, 07:18 PM
Send a message via AIM to Thefish561
The sheriff talkgroups listed in the database are correct. I can tell you that sometimes they use dispatch for tty when things are slow.. As for the radio feed, once its up please let me know and I will patch the osceola fire rescue website to it. I live to far away to provide a feed or I would do it myself..
Old 10-06-2009, 09:45 AM
Bolt21's Avatar
Ok, I'll take your word for it. I've heard West units dispatched, 10-51, 10-97, etc., etc., (not your typical TTY type traffic) on the West TTY talkgroup, so that's why I thought they had switched some things around. I usually ease through on I-4 sometime after 2145-2200hrs, if that has something to do with it.
Old 10-06-2009, 07:14 PM
I'd appreciate the feed, Harry. I have a RadioShack Pro 2096 TrunkTracker. I can pick up Osceola on scan, but not trunked.
Old 10-15-2009, 02:18 AM
Anyone have the old Station-41 {current renamed Station-45} tones?
Old 10-15-2009, 12:36 PM
FLRAILMAN's Avatar
Default Osceola County FD Live Feed
Station 41/45, is that the Poinciana Fire Dept. on Marigold Ave. across the street from the Poinciana Association of Villages building?
FLRAILMAN
Old 10-15-2009, 03:42 PM
Yes that was the old Station-41. I do not believe they use that station anymore after the hurricane damaged the building. They built a new station {Osceola Co Station-45/Polk Co Station-34} Close to the Solivita Sub. Div. Anyone can correct me if I am wrong, I haven't been there in several years.
Old 10-17-2009, 09:51 AM
Just to correct this info,
Osceola County Fire Rescue Station 65 is a joint station with Polk county fire department. The station is physically located in polk county at 1201 cypress parkway. it houses polk county ladder 34, tanker 34, als 27(rescue 34), osceola engine 65, rescue 65, and brush tanker 65. The old station 41 which was located on marigold was demolished after the hurricanes, then osceola did a renumbering and added an engine once moved into the new station, then once again the county did a renumbering and is now 65 since the division of the county into 3 battalions. Also as of Oct 5 polk county ems is no longer in this station since polk county fire is trying a merger and now als27 is staffed with polk county fire personell and will be renamed to rescue 34 very soon. Hope this helps.. On the scanner side of things, Osceola is dispatched on Tac 1 and response on Tac 3, polk is dispatched on Tac 1/VHF and respond on Tac 5 unless its a fire then on Tac 10
Old 10-17-2009, 02:25 PM
Gosh how many times they going to rename the Poinciana station? lol
This is like the 4th renaming
