Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Florida Radio Discussion Forum
Florida Radio Discussion Forum Forum for discussing Radio Information in the State of Florida.
Old 09-28-2009, 12:25 PM
Default St. Lucie County Frequencies - Which is Correct?
East Central Florida Scanner page, last updated on 06/09/15 lists the following frequencies:
853.7875 853.1500 852.6000 853.7500 853.0750 852.2750
853.6750 853.0500 852.2000 853.3000 852.8375 852.1250
853.2750 852.7750 851.7000 853.2500 852.7500 851.3125
853.2000 852.7000 851.2000
Radio Reference.com, last updated on 04/19/09 lists the following frequencies:
851.3125 852.2000 852.7000 852.8375 853.0500 853.0875
853.1500 853.2000 853.2500 853.2750 853.3000 853.6750
853.7500 853.7875 854.1250 854.2000 854.2750 854.6000
854.7000 854.7500 854.7750
Which is correct?
Old 10-04-2009, 09:20 AM
Thumbs up
I had better luck with East Central Florida Scanner page list, do to the one of frequencies of RR is a weaker CC not located in SLC. 73, David
Old 10-04-2009, 02:19 PM
I downloaded from RR into my 396xt using the table and it works perfectly. I have FT Pierce/Pt St Lucie and the county
Old 10-06-2009, 05:29 PM
i also d/l from rr and works fine. I monitor PSL and S.Lucie County when in the area (i travel up there a few times per month)
73's
K4VKS
Old 10-07-2009, 10:47 PM
I am no longer able to monitor St. Lucie County. Although the control channel (853.3000) is weak in my location, if I "Hold" my BDC396T on the control channel, it displays the SID and changing IDs. However, when scanning, it does not stop on an active channel and I hear nothing. I have manually set it on a known active channel and it still hears nothing. I have the St. Lucie system set up as a Motorola Type 2 800 MHz Custom since it was rebanded. I tried Motorola Type 2 800 MHz Standard but then I cannot even hear the control channel. Any suggestions would be appreciated.
Old 10-08-2009, 10:22 AM
Where are you located?
Old 10-08-2009, 11:57 AM
I live in Stuart (Port Salerno) but I work in Jensen Beach. In the parking lot at work I receive a very good signal but the BCD396T still does not stop on an active channel even though the display shows the active channel IDs. Since it is obviously hearing and understanding the control channel, I am stumped as to why I cannot copy any active channel.
Old 10-08-2009, 09:12 PM
I fixed the problem but I am still not sure what was wrong. I simply re-created the system. I double checked all the frequencies and they were all correct so I do not know why I was not receiving any audio. The only difference is the order in which the frequencies are entered as this time I simply cut and pasted them from the Radio Reference database.
