The few unencrypted talkgroups on the Tallahassee FD P25 system that are used during FSU home football games have been added to the Tallahassee Fire Department feed for the night. 85,000 expected, kick off at 8pm, and stadium gates are now open.
The feed includes alpha tags.
It has been a sunny, hot day, and there are already a fairly steady stream of EMS calls.
Generally, the two most active channels are:
EMS which is identified in the alpha tags as "EMS Stad 191"
LCSO Command Post channel which is identified in the alpha tags as "LCSO Sp Evnt 136"
(this is not the main CP channel, just the channel used by the county deputies that supplement FSU PD.)
Tallahassee Fire Department Live Scanner Audio Feed
(Just make sure to select the "Tallahassee Fire Department" P25 feed, not the "Tallahassee Area Fire Department" feed.)
