Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Florida Radio Discussion Forum
Florida Radio Discussion Forum Forum for discussing Radio Information in the State of Florida.
Old 10-13-2012, 1:39 PM
Default Live audio for FSU/Boston College game is UP
The few unencrypted talkgroups on the Tallahassee FD P25 system that are used during FSU home football games have been added to the Tallahassee Fire Department feed for the day.
The feed includes alpha tags.
FSU vs Boston College kick off is at 5:30 eastern, the audio generally starts to come to life about two hours prior to kick off when the stadium gates are opened and the command posts go live.
Alpha tags are included in the feed.
It is a hot day, currently >80 degrees, so with the heat and alcohol, there will no doubt be a lot of activity on the ems channel.
Generally, the two most active channels are:
EMS which is identified in the alpha tags as "EMS Stad 191"
LCSO Command Post channel which is identified in the alpha tags as "LCSO Sp Evnt 136"
(this is not the main CP channel, just the channel used by the county deputies that supplement FSU PD.)
Tallahassee Fire Department Live Scanner Audio Feed
(Just make sure to select the "Tallahassee Fire Department" P25 feed, not the "Tallahassee Area Fire Department" feed.)
Old 10-13-2012, 2:18 PM
Webcams of the streets around the stadium are the first half dozen or so here: http://www.lakemonkeybusiness.com/Allcams.html
They refresh about every 2 minutes.
