Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Florida Radio Discussion Forum
Florida Radio Discussion Forum Forum for discussing Radio Information in the State of Florida.
Old 11-14-2012, 1:19 PM
Default St Petersburg/Pinellas Co
Im new to the area,and new to scanning. Will the radio shack pro 95 work in st pete/pinellas? Any help appreciated!
Old 11-14-2012, 3:43 PM
jhal94's Avatar
Pinellas County public services uses a motorola type II smartzone system and has been rebanded the Pro-95 does not support rebanding. It can be found here: Pinellas County Public Services Trunking System, Pinellas County, Florida - Scanner Frequencies
St. Petersburg police is on the new digital project 25 pinellas digital system along with Treasure island and St. Pete Beach Here: http://www.radioreference.com/apps/db/?sid=4290. Treasure island and st. pete beach are also listed on the smartzone system but I haven't heard them on there in forever.
If you are looking to monitor the Smartzone system it is analog but your scanner doesn't support rebanding you can still scan it I believe (works on my pro-97). You cannot monitor the P25 system at all without a digital scanner.
Old 11-17-2012, 4:37 PM
I monitor analog only and can clearly pick up SPPS D1-D2-D3.
KJ4LXW
Old 11-18-2012, 1:33 PM
jhal94's Avatar
Hmm, It says they're depreciated on the database. Maybe its simulcast, I have no clue. odd
Old 11-19-2012, 7:47 AM
jeffmulter's Avatar
Location: Fort Mill, S.C. (just south of Charlotte, N.C.)
Default Comment, and a question
The only reason it "seems" like you're still receiving all the communications on the analog system on your Pro 97 is because only 2 of the 24 Ridgecrest site frequencies end in a zero (xxx.xxx0 MHz.), and none of the Toytown frequencies end in a zero.
Non-rebandable scanners cannot convert the channel numbers assigned to the .xxx0 frequencies in the 851-854 MHz band into the actual frequency.
So, if all the Ridgecrest site frequencies had an equal chance of being utilized, you would miss, on average, about 9% of that site's traffic due to rebanding. That's pretty good, considering some of the Motorola systems that rebanded from the 866-868 MHz segment have 50% or more frequencies ending in a zero.
Is anyone aware of whether the SPB PD's talkgroups will continue to be used when the county takes over patrol duties in the town ? Any other municipalities in the county seriously considering contracting law enforcement duties with the county ?
Jeff Multer
Fort Mill, S.C.
jamulter@aol.com
Old 11-21-2012, 1:22 PM
KI4VBR's Avatar
Default Welcome to Pinellas County
I am currently using a Pro95 for the feed I provide here at RR. I deselected groups 1 & 2 as they are south county and I am just broadcasting 3 & 4. It seems to work well and to the best of my knowledge, I dont think I am missing any traffic.
When they go "all" digital, I will make up my mind if I dedicate my 396XT to the task or not.
Best of luck with your monitoring and hope you enjoy living in Pinellas County.
Vince
Listening to: Icom 756Pro3, 706mk2G,730, Icom 2200H, RX7 Govt/Export, FunCube SDR, Yaseu 857D, Flex3000 SDR, 811h, FT-60 dual band, 396XT, 895XLT, HP1, Pro-95, Pro-97, Stridsberg Active Multi-Coupler
Old 11-22-2012, 5:29 PM
Tryton's Avatar
Nice Shack KI4VBR! 73's K1SPL
Equipment: Uniden Bearcat BCD996XT X 2
________________________________
K1SPL
