| Florida Radio Discussion Forum Forum for discussing Radio Information in the State of Florida. |
01-07-2013, 1:14 PM
Any Federal frequencies in Hillsborough county
I know about VA Hospital Tampa & Macill Air Base is there anything else? That is not encrypted.
Callsign: N4CYA
MotoTRBO: Motorola XPR 5550
NXDN: Icom F4261DT
Scanner: Uniden BCD996XT
01-08-2013, 12:45 PM
Try 163.05, St. Pete Coast Guard Station, their comms are usually encrypted but once in a while I hear transmissions in the clear.
Uniden 396XT, PSR-800 x2 , PSR-500, BC 250D, BC 245XLT, YAESU FRG-8800.
01-09-2013, 12:40 PM
If you are interested in Military Air frequencies, there is quite a few of them that are used at the Avon Park bombing range. I am able to copy it in North Pinellas, so depending on where you are, you should be able to copy all of the comms there. Let me know if you are interested.
Vince
Listening to: Icom 756Pro3, 706mk2G,730, Icom 2200H, RX7 Govt/Export, FunCube SDR, Yaseu 857D, Flex3000 SDR, 811h, FT-60 dual band, 396XT, 895XLT, HP1, Pro-95, Pro-97, Stridsberg Active Multi-Coupler
01-09-2013, 1:28 PM
I would put sometime into searching
138-144, 148-150.800, 162-174, 380-400, 400-420
and see what you can find...
01-09-2013, 1:46 PM
+ .6
162.6 so you can bypass the NOAA broadcast stations.
01-09-2013, 3:54 PM
Yeah, but you miss the stuff between 162.0 and 162.4 MHz - There is stuff there!
- Chris
01-09-2013, 4:24 PM
Do tell....
- Chris
Thanks for pointing that out Chris. What type of traffic have you logged there and where are you located? I guess I need to reprogram my search limits.
Tnx,
V
01-10-2013, 6:23 AM
Thank You Chris !
Surprised No one has questioned my 400-420 and changed it to 406-420 either...
- Chris
01-10-2013, 6:27 AM
All depends on where you are....
USFS, US ACE, USCG, FBI, NMF, CBP, DoE, IWN, NPS, FIO, USSS, ICE, FAA, BLM, USF&W, IBWC, VA, DoL, USPS, USCP, TSA, DoA, - all found below 162.4000 Mhz
Tnx,
V
01-11-2013, 9:30 PM
Thanks Guys for the help. I'll scan through the listed frequencies to see what I find to listen to.
Callsign: N4CYA
NXDN: Icom F4261DT
