| Florida Radio Discussion Forum Forum for discussing Radio Information in the State of Florida. |
02-06-2013, 7:04 PM
Sarasota County
I have Charlotte County and Sarasota County in my BC796D rebanded scanner. Charlotte County works perfect and Sarasota County is static when there is a hit. Is Sarasota County encripted and is there a procedure to clear the static? Dudeboy6
02-06-2013, 8:18 PM
mine is fine
i live in charlotte county and just tried north port it came in fine
sarasota is digital and has limited use of encryption
they also have fd and ems doing both
are you close enough for good reception?
i also have them in a separate folder (venice,north port,high hat,englewood,sarasota,osprey) and i change to whichever is closer
try the single approach and see what happens
02-07-2013, 8:15 AM
Sarasota County problems
I live in Englewood and get good reception in Charlotte County including Punta Gorda PD. Sarasota County is one of four locations in the US that is using Motorola Astro IMBE system and I can not get anything but static when there is a hit. On weebsite suggested that special programming or software may be needed. I am using BC796D rebanded with ARC250 pro software. Any help will be greatly appreciated.
Nick Karl
02-07-2013, 8:42 AM
ok
i am not familiar with your radio sorry
first a correction to fire and ems in sarasota they use both digital and analog
the reason you hear punta gorda is charlotte county is broadcast across the county so..
if you are out at the airport you can hear someone on a handheld at englewood beach
every tower broadcasts at the same time (they have to be set very precisely to do this)
sarasota is P25 i hope your radio is set up for it
02-08-2013, 10:34 AM
Nick Karl
Where did you get the information that Sarasota Co. is one of only 4 locations using IMBE?
If Sarasota was using a version of digital that was not compatible with your scanner you would not hear anything. Vselp was the original digital.
02-14-2013, 3:57 PM
That Wiki information is submitted by members and IS NOT an up-to-date list of agencies using these systems.
And it states...
"Some agencies using Motorola ASTRO IMBE systems include the City of Baltimore, the State of South Dakota, the State of Ohio, the Metro Washington Airports Authority, Fairfax County VA, and Sarasota County FL."
02-15-2013, 12:43 PM
Ok here's a straight forward question what, if anything, can be monitored on the Sarasota system??
02-15-2013, 3:01 PM
Everything can be monitored with a Digital Scanner except about four encrypted talk groups.
Please change E-mai address to above
02-15-2013, 4:13 PM
works for me
i just checked north port 853.7875 and all was ok
btw i grew up in hillsdale and went to 'hills' grad 77
02-15-2013, 5:47 PM
Originally Posted by jaymatt1978
The RR database is accurate for Sarasota County Public Safety Trunking System. With it programmed into your digital capable scanner, you will be able to monitor all agencies and talkgroups listed. There is very little (if any) encryption.
Steve
N3VRX
02-15-2013, 7:24 PM
Thanks and as fate would have it I graduated in '98 from Pascack Valley
02-19-2013, 10:46 AM
I was in Sarasota this past weekend (Feb 15-17) and heard everything just fine. I stayed over by the airport and I have a Pro 106. I also listened to the Manatee County system as it is listed here in the database.
Shadcall
Pro 106 Pro 163 Pro 164
02-21-2013, 7:16 PM
I have a bc796d rebanded and can not get anything in Sarasota Co. I have tried many ways to program Sarasota Co but no luck. I need help Dudeboy6
02-21-2013, 7:59 PM
Here is the rebanding table I copied from my programming I used this past weekend.
Lo channel hi channel Offset Base Step
440 559 440 851.0250 25.0
0 719 0 851.0125 25.0
720 759 0 848.0000 25.0
815 831 0 846.6250 25.0
958 958 958 868.9750 25.0
961 1022 0 843.4000 25.0
I tried to space it out but it won't let me.
Shadcall
