Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Florida Radio Discussion Forum
Florida Radio Discussion Forum - Forum for discussing Radio Information in the State of Florida.
  #61 (permalink)
Old 01-12-2018, 2:46 PM
Originally Posted by ke4crc View Post
Can NXDN be Decoded?
Apart from using an actual Kenwood radio...
Kenwood radios will not pass audio from a trunk system unless the radio ESN is provisioned in the system. Kenwood radios will not pass audio from a trunk system even if all the frequencies are programmed as conventional NXDN channels.
Interoperatablity is not a technology, it is an attitude!!!
  #62 (permalink)
Old 01-12-2018, 3:11 PM
Before you go off the left side kn1n, I am decoding type d with my 5700 with no issue at all. I drive through that county so I am speaking with firm and valid accountability here.
I scan it using conventional scan, nxdn. I decode the TG, and the uid.
They are type D, totally different than the type C.
They currently are NOT encrypted.
The system is not using esn validate for type D either.
Edit: I have VHF icom radios, and it follows fine cause I know the system info too. 5700 Kenwood is type C only in trunk mode.
Sent from my SM-G935P using Tapatalk
  #63 (permalink)
Old 01-12-2018, 3:42 PM
Fair enough. I was under the impression they would not pass audio from trunk systems in conventional mode. Thank you for this information
  #64 (permalink)
Old 01-12-2018, 3:46 PM
Yeah, type C is total wicked but I have heard from none ran systems you can monitor them, site equals ran code, and scan those channels.
  #65 (permalink)
Old 01-14-2018, 9:22 AM
The Levy county system is multisite conventional NXDN with 6 sites total, it is NOT type D trunking. Dixie county is running a similar system.
  #66 (permalink)
Old 01-14-2018, 9:25 AM
troymail's Avatar
conventional?
and, Dixie is listed as a Type D:
https://www.radioreference.com/apps/db/?sid=8821
Unication G5(UHF)
  #67 (permalink)
Old 01-14-2018, 9:30 AM
Both systems are conventional
  #68 (permalink)
Old 01-14-2018, 9:31 AM
troymail's Avatar
Hmmm... wonder why Dixie is listed as a trunk system then?
Unication G5(UHF)
  #69 (permalink)
Old 01-15-2018, 9:53 AM
Originally Posted by troymail View Post
conventional?
yes, from valid sources, they reverted to multi-site conventional. it was trunked.
  #70 (permalink)
Old 01-15-2018, 10:18 AM
troymail's Avatar
Can someone in the area with knowledge submit update (s) to the database?
Unication G5(UHF)
  #71 (permalink)
Old 02-12-2018, 8:06 PM
Simple Question - Can Levy Sheriff be picked up on any scanner available today? If so, What do I need to listen in?
  #72 (permalink)
Old 02-12-2018, 8:08 PM
Any one of the ones that can do NXDN.
I use my work radios, not sure what's out there to be honest.
  #73 (permalink)
Old 02-13-2018, 7:52 AM
Nasby's Avatar
Whistler TRX-1 or TRX-2.
  #74 (permalink)
Old 02-13-2018, 8:33 PM
And these will get both sides of the conversation or is it a hit or miss deal?
  #75 (permalink)
Old 02-13-2018, 9:08 PM
troymail's Avatar
As long as it isn't encrypted, you should hear both sides.
Unication G5(UHF)
  #76 (permalink)
Old 02-13-2018, 9:17 PM
It's conventional, both....
Tags
fla nxdn, levy county, nxdn
