Go Back   The RadioReference.com Forums > Site Administration Forums > Forums Administration
Forums Administration Discussions regarding these forums
Old 03-22-2009, 09:28 AM
45SigSauer's Avatar
Default Can't tell what I read
Not sure what changed. I remember in the past when I read a thread it would show up as not so bold font, what can I change to make this happen again? Thanks.
Proud Member/President: N.A.S.W.P
National Association for the Survival of White People
(Spoof of the N.A.A.C.P to show the idiocy of the racist double standard).
Old 03-22-2009, 09:42 AM
bezking's Avatar
Moderator and DB Admin
Send a message via AIM to bezking
In the new post screen, it should show up as not-highlighted.
--bezking
Moderator, NY-NJ DBA, Wiki Admin
bezking @ radioreference.com
Old 03-22-2009, 11:40 AM
loumaag's Avatar
Moderator
The bolding and highlighting work the same when viewed from the forum index, if you aren't seeing the above or below representations, something is wrong at your end.
Lou Maag
Rules and Guidelines for Forum Post Content
Old 03-23-2009, 09:17 PM
wayne_h's Avatar
Forums Manager
Send a message via AIM to wayne_h
Moved. Please read the forum's Stickies.
-Wayne
Please contact me via email for a faster response.
Forum Rules and Guidelines
Old 03-23-2009, 09:22 PM
bonus1331's Avatar
Interestingly, when I go through the forums at home with FF; the yellow doesn't go away after I've read a post.
However, using IE at work; it does change to white after reading.
David
BCT-15/BC780/BR330T/BCD396XT
Old 03-23-2009, 10:20 PM
Which FF version are you on, David? No problem with mine changing from highlighted to non (plain white) on FF 3.0.7
BCD996T-BCD396XT-BCD396T-PSR500-BR330T-BC246T-BC250D-BC780XLT
Old 03-24-2009, 08:54 AM
bonus1331's Avatar
I'm using the same.
Wonder if one of the extensions is causing the difference?
I'm using AdBlockPlus to get rid of website garbage.
David
Similar Threads
Can you read Unitrunker data offline? wise871 Trunking Control Channel Decoding 1 01-06-2007 03:44 PM
interesting read on antennas nycirnwrkr Antennas and Coax Forum 1 09-13-2006 09:13 AM
Easier to Read Manual for the SC230 trunker Uniden Scanners 0 08-17-2006 03:32 PM
Easier to Read BC246T Manual trunker Uniden Scanners 0 07-21-2005 06:40 PM
'Mark all topics read'.... boomboy64 System-wide Administration 2 07-28-2004 02:57 PM
