Originally Posted by MaxMan1986
All you have to do is click the "Quote" button. Then, just type your post either above or below that text, depending on where you want the quote to appear.
Try experimenting with it and you'll get the hang of it in no time.
You can also see all of the "commands" that can be used in the text box when you create a post
on this page. When I first started participating in forums, I printed these codes out (several pages worth) and I still keep them beside my computer.
Another thing you should check is in your
User CP. Go to your
User CP and go down to "Settings and Options" in the left panel. Then click on "Edit Options." On the next page that opens, scroll all the way to the bottom and find the section labeled " Miscellaneous Options." There is a drop-down menu there. Check that menu and make sure you have "Standard Editor - Extra Formatting Controls" selected.
Mac or not, you should be able to create the quotes and whatnot that you are wondering about.
