Other Way Around!
Actually, it works the opposite way. If you sign in to the forums portal here every time you visit, the threads that have NEW messages (the threads you HAVEN'T read through to the end) will be highlighted yellow. Inside that thread, you can click on "first unread message" and go directly there. This has something to do with cookies, so make sure FireFox is set to accept cookies - at least from RR. I'm running FF3.5.2 and this works perfectly as I've described.
Remember: no matter where you go - there you are!
[Buckaroo Bonzai]
Reason: corrected typo
