Go Back   The RadioReference.com Forums > Site Administration Forums > Forums Administration
Forums Administration For administrative questions about the forums or problems with its use. Before you ask, did you read here first?
Old 12-21-2011, 10:13 PM
Default posts marked read without reading
I have noticed that if I come to the forum and read a few posts then come back a few hours later to read some more. That all the posts are now marked as read without me reading them. Is there a setting somewhere that I can adjust? I don't want any posts to be marked as read until I read them.
Old 12-21-2011, 10:42 PM
WayneH's Avatar
Forums Manager
That's the default operation of the board. When the board sees you idle longer than a certain time it sets you as left the site and marks everything read.
There's nothing you or we can do that won't affect everyone else.
-Wayne
PM's are disabled. Please use email through my profile or: wayne_h at radioreference dot com
Please do not reply to my moderator activity. I do not follow those threads.
Old 12-21-2011, 10:47 PM
I don't understand why it would be setup this way. It should not mark threads as read until I read them. This is the first forum I have ever visited that is setup like this. There is no way to change this??
edited to add: It also appears to not mark messages as read when I have read them.
Old 12-21-2011, 11:03 PM
It annoys me too, but it probably has something to do with database complexity. The server would have to save an additional couple of toggles for every user. It might be a scaling issue.
I know that when we changed how our data was stored on a server by adding one field, it quadrupled the storage because of the time stamping...
List of obsolete radios.
List of degrees and certificates to impress people.
List of other information which is no one's business.
Old 12-21-2011, 11:30 PM
WayneH's Avatar
Forums Manager
You're correct. Each member then requires the need to store a saved state. With the amount of members and forums you can understand why we do it this way.
If it isn't then there's something going on on your end.
I'm rather sure that any other forum that saves the user's state is no where near as large as this one.
-Wayne
Old 12-22-2011, 9:01 AM
loumaag's Avatar
Moderator
This probably is the way you navigate the board. Are you actually seeing the actual post as not being read or does the forum show unread posts when you have gone in and read them all? The latter is a known problem for vBulletin. Unless you actually step backward through the index (each level) the forums will show unread posts even though you have read them all.
