D
DaveNF2G
Guest
Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Long text may have been implicitly wrapped, causing it to be counted as multiple lines.
This is a bug. Either we are allowed four lines, or we are limited by the word wrapping in the signature block editor. Both rules should have the same result and the intended result needs to be stated clearly.
As you can see below, my signature is currently 3 lines long. It takes four lines in the much narrower editor. Consequently, I am unable to add the supposedly permitted fourth line.
