Go Back   The RadioReference.com Forums > Site Administration Forums > Forums Administration
Forums Administration - For administrative questions about the forums or problems with its use. Before you ask, did you read here first?
Old 11-06-2018, 2:29 PM
Default Homepage Forums Posts Slow Updating
Removed as not an issue
Whistler TRX-1, Radio Shack Pro-668 (mod), Pro-197, Pro-651, Pro-106, Pro-96
Baofeng 888, UV82, UVB5, Connect Systems CS750
Old 11-06-2018, 2:36 PM
mule1075's Avatar
Originally Posted by N1GAW View Post
Compared to looking at "Today's Posts" or Tapatalk, the lists of posts on the home page appears to be updating slower than normal. Usually it takes a minute or two, but this afternoon it appears to be taking an hour or more.
Just curious about the cause.
Tapatalk's timeline is working fine for me.
Uniden SDS100/780XLT Motorola HT1000/GM360 Whistler TRX-1
Old 11-06-2018, 2:38 PM
I just noticed that the time stamps on homepage are different, they are one hour behind.
Old 11-06-2018, 2:41 PM
mule1075's Avatar
I just refreshed homepage and most recent post is from 13:36:50, compared to the Today's Post section where it is 14:36
Sent from my LG-Q710AL using Tapatalk
Could be a issue while the forums software gets switched over. Go into you're profile and see if the time got changed from standard to daylight savings or vice versa.
Old 11-06-2018, 2:50 PM
Where do I go to check the timezone (daylight savings time), I can't seem to find it in my profile.
Old 11-06-2018, 3:05 PM
User CP ---> Edit Options ---> Date and Time Options
Old 11-06-2018, 3:14 PM
Thanks found it, now I'm confused. Time there is showing correctly 3:11pm, but posts only on the home page are an hour behind. My DST setting is auto but changing it to off makes no difference.
In the forums itself it is showing the correct time.
Thanks for the help!
