| General Scanning Discussion For general questions not specific to a model of scanner or general discussion of use of a scanner. Location specific posts should be directed to the regional forums listed below. |
10-24-2008, 7:58 AM
I think a recorder (and have suggested it in the past) would be an excellent idea for a scanner.
With today's tech it shouldn't be that difficult to incorporate a audio recorder into a scanner. What would be great is if they would offer the recorder to record to removable SD cards. That way you could expand your media if necessary.
Also, do you realize how much audio you could record on a 2 GB card? Several hours worth if you wanted it.
10-24-2008, 8:14 AM
Some kenwoods have this. Keeps the last 30 seconds of audio.
11-01-2008, 9:00 PM
Originally Posted by SIG-INT
Very interesting. At the very least it shows that something tiny like that is capable and is less than $10. Integration of something similar doesn't seem like it would be a big obstacle for a manufacturer.
Anyway... I just put this feeler out there on a whim... Just seemed like a useful feature. I again appreciate the responses.
AndrewCCM
Crystal Clear Media
BCD396T, BCT15, PRO-2026, PRO-2046, Kenwood TK840, Eton E1XM, ST2, Wilson 800 Yagi, CM Rotator, iPhone with Scanner911 and Action Scanner
11-01-2008, 9:43 PM
Originally Posted by lugoffman
Well you could also go to http://www.scanamerica.us/index.php and see if they got a feed set up for your area as to what you was monitoring. If they do not you could get a feed started for your area and it will record everything that is active for that feed and you can go back into the archive and look it up and replay it THIS IS FREE !! to do good luck http://tx.scanamerica.us/index.php looks like dallas does not have a feed but you can start one for free if you got a extra scanner laying around it's easy to do just email gordon@scanamerica.us and he will get you set up for the feed
 just thought i would quote what i said earlyer it is cheaper
11-01-2008, 9:50 PM
Yeah.. But driving around in my car and hearing something that I wanted to replay real fast doesn't lend itself to that particular solution. However, I will check it out for home scanning or when I have my laptop available.
AndrewCCM
Crystal Clear Media
11-01-2008, 10:32 PM
If I remember correctly the Icom R20 has a recording feature.
11-01-2008, 10:42 PM
Not Posting
Correct. AOR also.
11-02-2008, 3:15 PM
look at it this way, while you are listening to the playback, you might miss something much more important that what you had previously missed, so then if we had this feature, people would want the playback to only play when the radio did not have any incoming traffic. yadda yadda...lol
11-02-2008, 3:53 PM
That would be a risk I take though... I think the number of times it would help (missing the address, not sure who called for help, etc.) would more than outweigh the "playing over audio." And since it's a separate circuit, you could still have the live audio playing if needed.
11-03-2008, 6:06 AM
It would not be too difficult to design a unit that would step back, play recorded audio 20 seconds old and then catch up to real time. Broadcast delay units do things similar to that.
Some posts can be interpreted in various ways.
Mine generally mean exactly what they say.
