G
goodzyz
Guest
:roll: who can tell me what is the meaning for this sentence"DMR equipment having an integral antenna and working in Direct Mode (unit-to-unit) under a general authorization with no individual rights operation."
In the US the license states that it gives no proprietary interest to the licensee. Maybe in some European countries (or in the EU) this is different and one only needs a license to use the frequency, not rights to it.goodzyz said:under a general authorization with no individual rights operation."
Al42 said:In the US the license states that it gives no proprietary interest to the licensee. Maybe in some European countries (or in the EU) this is different and one only needs a license to use the frequency, not rights to it.goodzyz said:under a general authorization with no individual rights operation."
It would help if you posted the name of the document (and the name of the issuing authority) you got this from.
bsavery said:Not quite what you asked but.....
ETSI is the European Telecommunications Standards Institute. Similar to ANSI is in the US, but only in matters pertaining to telecom where ANSI covers everything.
CEPT is the European equalivalent to the FCC.
So, unless someone knows European licensing and standards, it'll be hard to get an accurate answer.
And if you don't live in (or plan on building products for) Europe, it don't matter! :wink:
Bob
Or you need to hire someone whose field of expertise is the European communications laws.goodzyz said:but I want to build products for european market,so I need to know this
Al42 said:Or you need to hire someone whose field of expertise is the European communications laws.goodzyz said:but I want to build products for european market,so I need to know this
goodzyz said:but how should I find the expertise in this field? I am in China.
N_Jay said:goodzyz said:but how should I find the expertise in this field? I am in China.
You contact some of your trading partners in the EU and start discussions.
Tier I: DMR equipment having an integral antenna and working in Direct Mode (unit-to-unit) under a general authorization with no individual rights operation.
This sounds like unlicensed FRS like communications
Tier II: DMR systems operating under individual licences working in Direct Mode (unit-to-unit) or using a Base Station (BS) for repeating.
This soulds like traditional/conventional land mobile like communications.
Tier III: DMR trunking systems under individual licences operating with a controller function that automatically regulates the communications.
This sounds like trunking/networked like communications.
If you are having trouble understanding the scope of the standard, you are going to need significant help when you get to the technical details.
bsavery said:Goodzyz.... I would suggest you do a search for "European radio consultant" or similar on the internet. Given the amount of radio and rf certifiable equipment built in China these days, you may even find someone that offices in China as well as Europe.
Just out of curiosity, if you can say that is, what are you planning on marketing there?
Good luck!
Bob
