Old 02-13-2010, 7:02 PM
Default Walkie Talkies... frequencies?
I'd like to able to scan motorola/cobra walkie talkies. Anyone know where I could find the frequencies for them?
Old 02-13-2010, 7:07 PM
GROCKSHD's Avatar
If you are talking about FRS/GMRS
Channel Type Frequency
1 FRS / GMRS 462.5625
2 FRS / GMRS 462.5875
3 FRS / GMRS 462.6125
4 FRS / GMRS 462.6375
5 FRS / GMRS 462.6625
6 FRS / GMRS 462.6875
7 FRS / GMRS 462.7125
8 FRS 467.5625
9 FRS 467.5875
10 FRS 467.6125
11 FRS 467.6375
12 FRS 467.6625
13 FRS 467.6875
14 FRS 467.7125
15 GMRS 462.5500
16 GMRS 462.5750
17 GMRS 462.6000
18 GMRS 462.6250
19 GMRS 462.6500
20 GMRS 462.6750
21 GMRS 462.7000
22 GMRS 462.7250
http://www.buytwowayradios.com/blog/...equencies.aspx
Old 02-13-2010, 7:08 PM
This should be what you're looking for
GMRS Repeater Output / Simplex (1) 462.550
462.5625 FRS Ch 1 (GMRS 5 w. allowed)
GMRS Repeater Output / Simplex (2) 462.575
462.5875 FRS Ch 2(GMRS 5 w. allowed)
GMRS Repeater Output / Simplex (3) 462.600
462.6125 FRS Ch 3(GMRS 5 w. allowed)
GMRS Repeater Output / Simplex (4) 462.625
462.6375 FRS Ch 4(GMRS 5 w. allowed)
GMRS Repeater Output / Simplex (5) 462.650
462.6625 FRS Ch 5 (GMRS 5 w. allowed)
GMRS Repeater Output / Simplex (6) 462.675
462.6875 FRS Ch 6(GMRS 5 w. allowed)
GMRS Repeater Output / Simplex (7) 462.700
462.7125 FRS Ch 7 (GMRS 5 w. allowed)
GMRS Repeater Output / Simplex (8) 462.725
GMRS Repeater Input (1) 467.550
467.5625 FRS Ch 8 GMRS not allowed)
GMRS Repeater Input (2) 467.575
467.5875 FRS Ch 9(GMRS not allowed)
GMRS Repeater Input (3) 467.600
467.6125 FRS Ch 10 (GMRS not allowed)
GMRS Repeater Input (4) 467.625
467.6375 FRS Ch 11 (GMRS not allowed)
GMRS Repeater Input (5) 467.650
467.6625 FRS Ch 12 (GMRS not allowed)
GMRS Repeater Input (6) 467.675
467.6875 FRS Ch 13 (GMRS not allowed)
GMRS Repeater Input (7) 467.700
467.7125 FRS Ch 14 (GMRS not allowed)
GMRS Repeater Input (8) 467.725
Old 02-13-2010, 7:53 PM
HillWalker's Avatar
If ever visiting Europe, most operate on Private Mobile Radio (PMR), which is similar to FRS but is in a completely different band. Its short range so it only works over about three miles on top range units. Worth noting the FRS/GMRS is illegal to use in Europe as it interferes with some Emergency Services UHF frequencies.
There are only eight pre-programmed channels, with the following frequencies:
1 446.00625
2 446.01875
3 446.03125
4 446.04375
5 446.05625
6 446.06875
7 446.08125
8 446.09375
Old 02-14-2010, 12:55 AM
Does that include all the sub channels?
As in, when I set the radio I have to set a big number and then a little number.
Channel 4, subchannel 6, for instance. Only other people on 4-6 can hear me or respond.
Thanks for the help, everyone
Edit: This is the type of radio I'm talking about:
http://www.bizrate.com/two-way-radio...-pid861555311/
edit again: Looks like the subchannels I mentioned are actually "privacy codes". From the feature list:
"Has 22-frequency capacity with 121 privacy codes to reduce interruptions during transmission."
Old 02-14-2010, 1:44 AM
Astrak's Avatar
Those radios only have the 22 channel FRS/GMRS frequencies listed above.
WWW.APSN.US
Old 02-14-2010, 8:16 AM
loumaag's Avatar
Silent Key - Aug 2014
No such thing, as you figured out later according to your edit.
No, you can only hear someone on 4-6. Anyone listening without setting a "Privacy Code" hears everything on the frequency within range.
Old 02-14-2010, 8:25 AM
Ahhh, cool, thanks
Old 02-14-2010, 10:47 AM
Are the Privacy Codes standardized in any way? i.e. Industry wide, by make, or model.
File it under new uses for old scanners but I was wondering if you could program them into a CTSS capable scanner. That way you could monitor individual conversations instead of having them all garbled together on the same frequencies. Like talk around channels for public safety.
I don't have (nor have I played with) a GMRS radio, but I'm curious.
Old 02-14-2010, 12:57 PM
KE5TLF's Avatar
standard CTCSS (PL) tones
Old 02-14-2010, 2:20 PM
Guess this is a start:
www.popularwireless.com/codetable.html
Old 02-14-2010, 3:17 PM
GROCKSHD's Avatar
I just pulled out my motorcycle helmet which I have a Chatterbox GMRS X1 attatched to it. I talk on Channel 7 sub-code 7. Using my 396XT I was able to do a service search and it recieved my transmission on 462,7125 C85.4 . I plugged that into the scanner, and changed my chatterbox to Channel 7 sub-code 8, Which is 462.7125 C88.5. My scanner was unable to pick up the transmission, so you can weed out other transmissions on the same frequency as long as you know which CTCSS code you need.
Old 02-14-2010, 4:23 PM
loumaag's Avatar
Default Thread Moved
I have moved the thread as it really has nothing to do with the Database. This is really basic scanning information.
