  #141 (permalink)
Old 04-29-2014, 4:13 PM
bill4long's Avatar
Originally Posted by KB7MIB View Post
Using CTCSS or DCS does not reduce interference. It actually prevents you from hearing co-channel users, leading to mutual interference to all parties who are using CTCSS or DCS.
It can reduce interference, if by "interference" one means hearing stations that you do not want to hear, which can obviously be disruptive, especially to low information Wal-Tards.
Given my monitoring of the local situation, I would guess that most of the non-Walmart MURS signals that Wal-Tards hear are not close enough to actually "double" with an inside signal. Walmart could at least eliminate hearing "outside" traffic that if they used tone squelch. My guess is they would be better off with tone squelch than without it.
  #142 (permalink)
Old 04-29-2014, 6:01 PM
captaincab's Avatar
Location: monitoring delco pa with gre psr300 pro2053 and bearcat 560xlt
shoplifters would just saying. it has happended a lot in fact the pro's do it.
Originally Posted by MarkEagleUSA View Post
Not to rain on anyone's parade, but why would anyone want to listen to Walmart transmissions?
  #143 (permalink)
Old 04-29-2014, 7:24 PM
be cause they can
  #144 (permalink)
Old 04-29-2014, 7:40 PM
firerick100's Avatar
Default Walmart Scanner Codes
The Waterbury ct one uses a freq a Local fd uses as a third fg channel they are boring to listen to
(1)396T( 3) 996 xt's(2) 396 xt's (1) Ht 1250 (VHF)(1)Ht 1550 xls (UHF)
(1) HT 1550 xls (vhf)(1)MTS 2000 type 3 (1) Motorola XTS 3000
Rickbryce@twitter
www.rescue9photography.com
  #145 (permalink)
Old 05-03-2014, 3:46 PM
Austin, MN uses 154.570. (thanks to the Close Call™ function on my 396XT)
  #146 (permalink)
Old 05-04-2014, 2:21 AM
JoeyC's Avatar
What the hell is a Walmart Scanner Code?
  #147 (permalink)
Old 05-04-2014, 2:35 AM
W8VFD's Avatar
Talking Scanner Code Definition?
I think it's those little barcodes on the shelves that they use for inventory purposes, lol...
List of scanners & radios that nobody cares about...
My Feed
Andover VFD
  #148 (permalink)
Old 05-04-2014, 3:50 AM
pinballwiz86's Avatar
They meant to write, "Walmart scanner frequency" or some such.
In my area they are all on "blue dot" 154.57 MHz.
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
  #149 (permalink)
Old 06-26-2014, 1:49 AM
aspicer's Avatar
Default What are those flags?
Originally Posted by rescue161 View Post
Just remember, it is still illegal for anyone to "mess with" Walmart or any other business. License-by-rule has a meaning. Just because you don't need a license does not mean that you can interfere with any other station. That's a big problem with CB. People tend to just talk over other stations because they believe that since no license is required, that nobody has exclusive rights to the frequency. But, if someone is using a frequency, then their operation should not be interfered with until their operation is complete. That is what a monitor button is for. You push the monitor button to open the squelch so you can listen for any other station. If nothing is heard, it is safe to transmit; If you hear someone, you don't.
What do those flags mean near "Hams Against Magnetic Mounts"? I had trouble finding that Red-White-Red-White-Red pennant flag. I found it in Russian Navy Code and Signals flags. I don't think it is an international flag. Does it mean "Magnetic" somewhere? So your horizontal flag hoist means "Magnetic W T F"? What the French?
73 de KA4UDX,
ex USN RM and SM rating (and QMOW)
  #150 (permalink)
Old 06-26-2014, 4:41 AM
rescue161's Avatar
KE4FHH
It is a code/answer signal flag.
http://www.navy.mil/navydata/nav_legacy.asp?id=273
  #151 (permalink)
Old 06-26-2014, 9:38 AM
what is the actual codes they use? like the color codes
Scanners: BCT-15, Pro-106, Whistler 1040
Radios: Icom 3161, Connect Systems CS580
John 15:13 - Greater love hath no man than this, that a man lay down his life for his friends.
  #152 (permalink)
Old 06-26-2014, 12:10 PM
teufler's Avatar
when did the navy change the hotel flag? It use to be white with a red dot in the middle, hence the hotel flag.
WD0GSYDMR ID 3129226 AND 3129304
BC-396XT,780XLT,TENTEC PARAGON, TYT-2017, MD-390, DM-5R+, ANYTONE 5888,VX10, VX7, VX3,TERMN-8R, F8-HP, GT3, UV-5, UV-3R, WOUXUN UV-8D,JUENTAI UV8DR,
  #153 (permalink)
Old 06-26-2014, 3:07 PM
rescue161's Avatar
KE4FHH
The signal flags are saying, "[Code Follows] Whiskey Tango Foxtrot."
  #154 (permalink)
Old 06-26-2014, 3:12 PM
wtp wtp is online now
Default real
my real initials...missed it by that much ()
some actually see it as an f anyway.
  #155 (permalink)
Old 06-26-2014, 6:43 PM
VE6BRW's Avatar
Originally Posted by tjg66 View Post
If anyone wants to know, i discovered the freqs that walmart uses for thier handheld radios. they are 154.600 and 154.570
So if you found some frequencies then why does the title of this posting say "codes" hmmmm 2 totally different thing.
  #156 (permalink)
Old 06-26-2014, 8:40 PM
milf's Avatar
Careful, I CAN hear you!
Just FYI, Wal Mart is upgrading to DMR (MotoTRBO) at many of their locations, so basic scanning of them is going to become problematic. Almost all of the new licenses for Wal Mart have now added the 7K60FXE etc to the emissions designations. Here in Indy I have verified at least some TRBO usage already.
APX6000XE
  #157 (permalink)
Old 06-26-2014, 10:43 PM
bravo14's Avatar
Had a feeling they would do this soon. I'll try the 3 wal marts in my area. I don't live too far from one.
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800 BCD536HP BCD436HP HomePatrol-1
YouTube http://www.youtube.com/user/staugfl1991 (videos)
YouTube http://www.youtube.com/user/scannerfreak91 (Scanners)
