| General Scanning Discussion For general questions not specific to a model of scanner or general discussion of use of a scanner. Location specific posts should be directed to the regional forums listed below. |
01-24-2011, 8:27 AM
Is there a scanner than can receive this VHF freq?
Hello,
I have searched around here and have not found what I am looking for. Is there a scanner on the market than can receive a VHF freq. such as: 156.0975?
I know that in a UHF status you can put in the 4th digit of the 5 which basically is a 12.5 k step in freq. Is there a scanner able to do this in the VHF band? If so, which one?
RJ
01-24-2011, 11:10 AM
There are lots of scanners that will receive 156.0975 when tuned to 156.095 or 156.100. That's because the IF passband is wide enough that the slightly mistuned receiver still gets the signal.
Hopefully somebody else can point you to a scanner that will actually tune to the desired freq.
01-24-2011, 11:30 AM
WA1ATA,
Thanks for the reply. I will try that for now. I know that I programmed a Bearcat scanner once for a friend and messed up putting in the freq in the VHF and it actually kept the 4th digit as a 5, so it was going in the 12.5k steps but for the life of me I cannot remember the model # of it. All I do remember was that it was one of their mobile style units (not handheld)
RJ
01-24-2011, 11:45 AM
It's not a scanner, per se, but I use a Motorola HT1000 VHF model to receive/transmit on such "narrow band" VHF frequencies. They are available on eBay for ~$100. If you can't find one and you decide you want one, send me a PM here on RR. I have one I'll sell you. But check eBay first.
Ben -- N0BDW
Volunteer Firefighter
Owner of many radios (Yaesu, Icom, Motorola, Wouxun, etc etc)
01-24-2011, 12:04 PM
There are lots of scanners (GRE, Uniden, Radio Shack) that now do 7.5khz steps in the VHF band. The pro-163/164, and MANY others ( Almost all of the newer models). Just read the specs here on the Wiki, you are looking for 7.5khz steps.
01-24-2011, 7:58 PM
Even the older 780xlt will do 7.5khz. steps!
n9zas
01-25-2011, 9:05 PM
My BC780XLT, BC796D, & PRO-2055 will all do that freq. The 2 Bearcats need the steps changed to 7.5khz. My PRO-97 handheld will also do that freq.
Chuck in Detroit / NODAK 1
01-26-2011, 7:51 AM
HomePatrol certainly allows it. Of course you need to set it up with a 3rd party software package like ARC-Patrol, but the "quick frequency entry" menu allows it. It may or may-not actually tune this closely, but the entry is allowed and seems to be effective (at least in the quick frequency entry screen).
Bob Peloquin - KB1VUA
Uniden HomePatrol-1, BC100XLT,
R/S PRO-30, Pro-106, Pro-163 (feed provider)
