Old 05-09-2012, 1:15 AM
Wirelessly posted (Opera/9.80 (BREW; Opera Mini/5.63/27.1591; U; en) Presto/2.8.119 240X320 Samsung SCH-U660)
i have a pair of altec lansing mhp 136 wooden housing earbuds with a 1/8 mono plug on the end. Can i cut the earbuds where they branch off and solder the cut end to the fm discriminator of a scanner and insert the plug end in the 'line in' on my computer or would i be better off starting with just a piece of wire and soldering on a 1/8 plug?
equipment is a GRE PSR-500. Antenna is a 36" RadioShack Magnet Mount for home use and a Diamond RH519 for mobile.
Old 05-09-2012, 9:23 AM
ST-Bob's Avatar
First off, earbuds almost always have a stereo plug on them. It has a tip and a ring then the common ground connection furthest from the tip.
Learn to solder and get the right parts. Use RG-174 coaxial cable from the discriminator pin to the appropriate jack (RCA phone jacks are commonly used) with the shield properly grounded at both ends.
Bob Peloquin - KB1VUA
Uniden HomePatrol-1, BCD536HP
Old 05-09-2012, 10:22 AM
Thanks bob that's what I'll do. Luckily I do know how to solder.
