To make a usable paper label for a non-display HT you really need the small (8 or 9 point) type that you get on an Excel printout, along with the line boxes that are also available. First of all, you will be able to use like channels 1, 2, and 3 from your own memory, but you'll need to look at the label when you get above channel 3 or 4. Also, remember that you can, with Excel, make a black label with white typeface which is pretty slick and easily readable even with the small type size.
